Weird setup - help me design a system!
RandyL712
RandyL712 Posts: 2
edited November 2001 in Technical/Setup
It's time for a new system (will be my fourth Polk setup!).
I need in-walls for all but the center channel.
The center channel needs to be 4-5" deep or less. This limits me to the RM series, which is fine with me.
I want the tweeters to match! Do any of the RM series tweeters match an in-wall speaker?
Post edited by RandyL712 on
  • mjk91383
    mjk91383 Posts: 298
    are you trying to just buy one of the rm speakers (center)?
    from what i know, which isn't that much, you have to purchase the rm speakers as a set (4 sat, 1 cnt).
    i know you're talking about in wall speakers, but the 7200's are small enough to mount on the wall, they look damn fine, and they aren't but 4" deep... hope this helps.
    joe :D
