Thoughts on new RTI Setup
time to upgrade my $150 RCA HTIB.
Here are my current plans:
fronts: RTI A7
center: CSI A6
rear: RTI A5 or FXi A6 (leaning A5)
sub: PSW 125 or Klipsch SW 450 (leaning Klipsch)
receiver: Yamaha RX-A1000
Used mostly for HT, in a fairly large living room. Any feedback thoughts on the rear/sub choices (cost is about the same for the 2 in each category so I'm need from a performance perspective)?
fronts: RTI A7
center: CSI A6
Post edited by pidass on
I'm looking at a similar setup so I'm interested in hearing the replies.
Personally, I'd choose the FXi A6 as rears, but more for consideration of aesthetics; I'll more than likely wall mount them. I'm thinking that a wall mount will be somewhat less obtrusive.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
The RTia7/RTia5 combo with the CSia6 center channel will be a great HT system.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Looks like a nice set-up. Any of the speakers you listed will do well. I found the FXi A4's (have not heard the A6's) to be better suited for movies. They are more open and non directional.
That's an awesome system you got going on there. Just a matter of personal opinion but i'd take the Fxi's for surrounds, especially for HT. I can also say I would hands down take the Klipsch sub any day. It's a good sub and digs deep for movies, it'll blow that Psw125 away. The Psw505 is more comparable to the Klipsch than the Psw125. Good luck on the system and welcome to club polk.
Instead of a7's and a5's I'd get a pair of A9's/csi a6/ fxi a6's.
thanks for the insight, I thought about the A9's but that would add a significant amount to this project plus the A9's seem to be power hogs (and I have no plans for an amp in the immediate future).
I recommend the FX style speakers for the rear. I had a CSi5 along with four RTi10's at one time and replaced the rear set of RTi10's with a pair or FXi3's and preferred that set up for movies. I must admit four floorstanders is pretty nice for music though. I also tried RTi6's for a little bit but still prefered the FXi3 or FXi5 for the rear. You could always save money on getting either FXiA4's of FXi3's for the rear as well. I have owned both the FXi3's and FXi5's. The 5's are nice if you can get a good deal on them, but I am not sure if the price difference justifies the improvement in performance. You could always look for a deal on a pair for RTi12's instead of 9's to save money.
I would get the RTIA5s or RTI7s to start,as the A9's would need external amplication to truly shine,so an added cost."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
HT surrounds are intended to be mounted higher than a floorstanding speaker. Go FXi for surround. you'll have a nice system. Good luck!
Please see below for my recommendation. We could not be happier with our system for either movies or music.
Might agree with the post above that the 125 sub may not match well with your other selections, from a performance standpoint. I've heard the 505 is good ... wouldn't cut a corner there.Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
The PSW 505 is a better sub than the PSW 125. More powerful,goes lower,better build and has a removable grill. Its equally good for both Music and H/T. The 505 was originally built as part of the RTi Line with the Real Wood Vineer instead of Vinyl for the PSW 125. Your other RTI choices are very good...especially the Front 3.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Not sure the Yamaha is the best match for the RTi series. IMO bright receiver + bright speakers = way too bright. I would look at Harmon Kardon or Pioneer in addtion to the Onkyo. I would suggest using the FXi for surrand and moving some of that speaker buddget towards the subwoofer since you will use it mostly for HT.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I had a Yamaha Rxv1800 and I liked it with my Monitors but as soon as I got the Rti's it was way too bright for me. I sold it and got a pioneer vsx1120, I liked the sound a lot better.
