Center Speaker?
Racfan9
Racfan9 Posts: 13
edited February 2011 in Speakers
Which center speakers match up best with the tsi100's?
Terry
  • dfledezma
    dfledezma Posts: 148
    For the TSi100 200 and 300, the series match is the CS10, although you can get the CS1 series II which is basically the same, and almost the same finish as well. However if you upgrade to a bigger speaker in that family you better get the CS20 or CS2.
    Cheers,
