Blackstone TL2 Center speaker with TSi400?
jdmornai
edited February 2011 in Speakers
Hi,
Would it be an heresy to couple a Blackstone TL2 center channel with 2 TSi 400 floorstanding speakers? I've read that we need to timbre match all three front speakers so don't want to make a mistake buying the TL2.
The reason I want the TL2 is because the CS10 is way too big (there is not enough room underneath my TV). Any recommendation for a center channel speaker that would be slimmer and timbre match the TSi?
Thanks!
  • HTguru1982
    It won't be a perfect match but it will work. Is it possible to put your center speaker on a stand in front of the TV? That's how I'm able to use three identical RT7's as my front speakers.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • jdmornai
    No, unfortunately the TV is hanged on a wall and underneath there is a cheminey. I'm also looking at pairing the RTI A7 with this L2 center speaker but I'm really concerned that they may be too weak for these big RTI. What do you think?
