Thinking to upgrade to rtia9's
Slyder01
Slyder01 Posts: 115
edited February 2011 in Speakers
I'm thinking of replacing my 12 yr. old rt16's with a pair of rtia9's. Would this be much of an improvement considering i mostly use my system for HT. Also would my csi5 center match and would i need an external power amp to power these puppies!
Yamaha rx-a2000 AVR
Polk csi5 Center
Polk rt16 Main
Polk fxia6 Rear Surround
Paradigm Micro Rear Back
Onkyo bookshelf Front Presence (for now)
PSW 450 Front Sub
DSW MicroPro 4000 Front Sub
DSW MicroPro 2000 Rear Sub
Samsung c6300 60 inch LED
Sony BDPs370
Room Size 15x30
Post edited by Slyder01 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2011
    The RT16's are fine speakers, but upgrading to A9's would be beneficial in overall resolution, and bass articulation - they play deeper, and have a more muscial low end. The CSi5 isn't the spot on match, but it's close enough that I wouldn't worry about it.
    While you're at it, check out polkdirect on eBay, and spend $60 to change those Paradigm micro's to at least OWM3's.
    Cheers,
    Russ
    tonyb Posts: 33,019
    edited January 2011
    What Russ said......but as far as the amp question goes, you would be just ok running A9's with that receiver in 7 channel mode. An amp would help bring out the best in them. A nice step up for sure, good luck to you.
  • JimAckley
    JimAckley Posts: 1,138
    edited January 2011
    If you want some RTi A3s to match, I have some for sale!
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • Slyder01
    Slyder01 Posts: 115
    RuSsMaN wrote: »
    Cheers,
    Russ
    That's what i'm looking for is more bass out of the mains,, fortunately there are no dealers in my area for me to listen.
    I believe the paradigms are fine for now since there arent many(if any) movies in 7.1.. I will be replacing them eventually with maybe the fxia4's along with the front presence..I moved them to the rear when i upgraded to the fxia6's
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
