polk sda srs 2
timmyd
timmyd Posts: 26
edited February 2011 in Vintage Speakers
I came across a pair of polk sda srs 2,each speaker have 6 mid,3 tweeters and the 15" woofer,the drivers configuration is exactly the same as the 2.3 model,the cabinet size is same as 2.3,the only difference that I can see is:of the 6 mid,2 of them look different than the other 4,they do not have the dust cap cover and they're flat.I never see anything like that.They do have the pin/blade IC cable..I did some research and find out that the sda srs 2 only come with 4 mids and 2 tweeters +woofer,and the cabinet look substantially smaller than the 2.3.
I'm so confuse now:what exactly are those monster,anybody ever seen anything like that.
cheer
Post edited by timmyd on
  • Schurkey
    Schurkey Posts: 2,104
    edited January 2011
    Top and bottom MW drivers have goofy-looking inserts?
    SDA SRS 2.3.
    The SRS 2.3 TL has a set of drivers that all look the same, (conventional) and a different crossover.
    The older SDA SRS 2 (not the 2.3) has the same four (not 6) MW drivers and nearly identical crossover to the SDA 1B (blade/blade version) or SDA 1C (pin/blade version)
  • timmyd
    timmyd Posts: 26
    edited January 2011
    Schurkey wrote: »
    SDA SRS 2.3.
    Thank Schurkey,
    how do they sound compare to 2.3tl?
  • cincycat13
    cincycat13 Posts: 887
    edited January 2011
    http://www.polkaudio.com/forums/showthread.php?t=101691
    You can check the pictures in this thread to compare with the "donut" drivers. I have not heard the tl so I can't help with the second question.
  • cincycat13
    Reported casinosmel msg
  • Tour2ma
    Tour2ma Posts: 10,177
    timmyd wrote: »
    Thank Schurkey,
    A better question is "how do they sound?"
    Jesus, cinci... $300?
    More later,
    Tour...
    Vox Copuli
  • Schurkey
    timmyd wrote: »
    Thank Schurkey,
    Never heard any of the SRS line.
    First guess: 98% the same given the same room, same placement, and same equipment driving them.
    Folks spend thousands and thousands of dollars chasing the two percent. For some, it's worth it. For others, it's status. For a few...it relieves the boredom.
  • timmyd
    timmyd Posts: 26
    cincycat13 wrote: »
    yes these are the ones I saw,weird looking drivers,and look like they're all mislabeled as SDA SRS 2.
    Thank all you guys
    keep on rocking!
  • chandler9a
    chandler9a Posts: 878
    timmyd wrote: »
    Thank all you guys
    keep on rocking!
    Thats how its labeled on the back of the speaker so the seller might not know what they have or how much they are worth?
    Could be a good thing:wink:
  • flason
    flason Posts: 278
    You're going to love those speakers!!! I have the same 2.3's and have zero TL envy. Had help from Forum guys here for a tweeter\driver or 2 and polyswitch instructions. Everyone was very helpful. Great group of people. Enjoy.
  • timmyd
    timmyd Posts: 26
    flason wrote: »
    The guy want $380 for them,the speakers look dirty,been sitting in the garage for a year,cloth grilles need to be replaced,logo are missing,few nicks at the edges of cabinets,couple dust covers are pushed in,they do come with IC cable.I think they do worth the price but will required lot of work(mostly cleaning ) to make them look nice.
  • chandler9a
    If cleaning is all they need don't hesitate. However, is there any way you could listen to them? If they are that dirty, chances are they were never taken care of properly and other things could be damaged like blown drivers, tweeters, bad xovers...
    They could be totally fine but I would want to make sure there wasn't any serious internal damage first. Not that it wouldn't be a good project speaker at that price.
    Flason is right, they are great speakers but also, make sure you have room for them to sing:wink:
  • timmyd
    timmyd Posts: 26
    chandler9a wrote: »
    They do work fine,we did test them in the garage,I think I'll get them today,I do miss the SDA sound,it's addictive.
