Spiking SDA2B Monitors
brgman
brgman Posts: 2,859
edited January 2011 in Vintage Speakers
Has anyone ever spiked the 2B's that are not the capped style?
I thought of removing the sub-base and spiking the cab but thought i better ask to see if anyone has tried this before.(yes i searched but could not find a definitive example)
The cabs are in great shape but that sub-base is shaky and i thought this may be a good option.Thanks for any help.
I’M OFFENDED!!!!
Post edited by brgman on
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    edited January 2011
    I have not actually seen a pair of 2B's with the base. If the base is removable I would remove it and spike the cabinet.
    I actually through bolted my spikes through the bottom of my 2B's.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    F1nut Posts: 50,766
    edited January 2011
    Be sure to fill the original screw holes as the screws go all the way thru. Measure in 1" from each side of the corners, that will be where you drill the new holes for the T-nuts or whatever threaded insert you use.
  • brgman
    brgman Posts: 2,859
    edited January 2011
    Thanks.
    I’M OFFENDED!!!!
