Have You Listened to a High Power Amp?
dcmeigs
dcmeigs Posts: 708
edited February 2011 in 2 Channel Audio
Zingo has the very cool "low power" thread going now that has some great DIY and vintage tube gear. Let's see some photos of of the big iron here. I'll start with the badass Altec 1569A.
This is Altec was used in theaters and sports stadiums back in the day. It uses four EL34s in parallel push pull. It has two rectifiers, not because you need two, but for added reliability. One fails and nobody even notices until it's serviced. Check out the size of those transformers. Sexy.
Audio historians will someday recognize the 1569A as having the lowest WAF since man began keeping records. A pair of these rack mounted are absolutely perfect for serious the man cave.
It's roomy and comfortable to work in there. Look at the low parts count. The average talking beer opener has more parts. The EL34 is a 25 watt tube so this baby idles at 70 watts (per channel- it's mono) and should approach 90 watts at mid volume. With a pair of Voice of the Theater speakers, you could rock that man cave.
The world is full of answers, some are right and some are wrong. - Neil Young
Post edited by dcmeigs on
  • organ
    organ Posts: 4,969
    edited January 2011
    Wow! Would be awesome listening to metal with those powering some big horns. Thanks for sharing.
  • Hilbert
    Hilbert Posts: 316
    edited January 2011
    Is that thing for audio or reviving Frankenstein?
  • dcmeigs
    dcmeigs Posts: 708
    edited January 2011
    Hilbert wrote: »
    In the second photo, do you see the black box with two gauges behind the Altec? That's for kick-starting Frank.:biggrin:
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2011
    But the Volume scale doesn't go to 11...
    dcmeigs wrote: »
    Doesn't make it any less sexy, but one of the transformers (the smaller one most likely) is an output trannie, not an installed spare.
    Check out the schematic here...
    More later,
    Tour...
    Vox Copuli
  • dcmeigs
    dcmeigs Posts: 708
    edited January 2011
    Funny you should say that. I almost made a Spinal Tap remark when I saw the pot at 10. I did't play it that way (it's not even my amp), I had just sprayed deoxit and left it in that position.
    Tour2ma wrote: »
    here...
    It is the rectifiers that I referred to. Note that there are two 5U4s, the tubes with the largest envelopes. One would do the job nicely, but the second was installed for added reliability. You are correct about the transfos, the smaller is the OT.
  • Tour2ma
    edited January 2011
    Oops... The old, eye-sees-"rectifier"-brain-reads-"transformer" trick... :redface:... Sorry 'bout that.
    More later,
    Tour...
    Vox Copuli
  • skipf
    skipf Posts: 694
    edited January 2011
    Here is the highest power tube amp I've heard. It will handle any speaker with ease.
  • thuffman03
    thuffman03 Posts: 1,325
    edited January 2011
    The Carver Silver 9's are the biggest amps I have ever heard also.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    heiney9 Posts: 25,421
    edited January 2011
    As far as high power I listend to a Nakamich PA7-II when I worked in a high end audio store in the mid 80's as well as Adcom GFA 555 and various Yamaha's.
    The Nak was the sweetest all around with excellent, silky smooth highs and a very good midrange. Never sounded harsh even when you'd push it to edge of clipping. One thing it lacked was that last bit of low end "slam" the Adcom was good for.
    The Adcom 555, was a powerhouse, very detailed on top. Picky about the pre-amp used and I never used an Adcom pre-amp with it (they weren't the best choice back in the day.....the GFP-750 wasn't around then) nice midrange, not as warm as the Nakamichi but it had such great low end bass. Not overdone of sloppy just very deep and with the right amount of texture.
    The Yamaha amps never impressed me, they had more "rated" wpc than the Nak or Adcom, but they always shut down early when driving moderate loads like the original Mirage M1 or the larger A/D/S floor standers and the SDA SRS or KEF 107's. They were very blah sounding, never did anything really well other than look pretty. I still don't get why the "M" series amp like the M80 or M85 get so much love. They never impressed me at all, still don't.
    Kenwood M2 Basic line, a capable amp but unimpressive overall, very bland and just not enough bass extension. Could get a little harsh when pushed.
  • dcmeigs
    dcmeigs Posts: 708
    edited January 2011
    thuffman03 wrote: »
    Holy Moley! I don't suppose you'd need to heat that room in the winter! What speakers are they driving. (I know, any speakers they want! :biggrin:)
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2011
    I had to 2 Soundcraftsmen PM-840's bridged for 600 watts/rms @ 8ohms, and over 1200 watts peak. The Bose 901 series VI that were connected to this setup for many years, never distorted, nor were they ever able to make the clipping LED's light. It was woodieville, USA with power chord ROCK.
    I know it's audiophile blasphemy, but that system was FUN jack.
    edited January 2011
    I've listened to other high power amps, but just listened for a short time. The models I posted are those I lived with for awhile or had a lot of experience with. I'm sure there have been others but those are off the top
  • MarkTX
    MarkTX Posts: 58
