Down firing subwoofer on it's side?
Movieman
Movieman Posts: 7
I just changed the design of my home theater. My sub is now going to be placed on the floor below a cabinet. The down firing sub won't fit - if I lay it on it's side and use it as a front firing will that dramatically change the sound?
Post edited by Movieman on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2011
    Im sure it would being that its designed to be "down firing"....try it and see.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • rubin
    rubin Posts: 565
    edited January 2011
    SVS pb ultra is front firing, SVS pc ultra is down firing. Both subs use the same driver and amplifier. People who have put the SVS pc ultra on its side say it sounds and works fine.
  • kingtut
    kingtut Posts: 813
    edited February 2011
    My Hsu sub is on its side due to placement issue. No affect in sound.
  • dvdit
    dvdit Posts: 16
    edited November 2011
    I will be buying the Outlaw LFM-1 EX this BF and I plan to put it on it's side. Hope this won't affect the sound nor does any damage to the woofer or amp.
  • Glowrdr
    Glowrdr Posts: 1,103
    The Polk DSW subs have removeable feet, and extra pre-drilled holes just for this purpose. I'm sure it will be fine. Granted, it may change the sound profile a bit, but it probably wouldn't sound any different than any other front firing sub (apples to apples of course)
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    VR3 Posts: 29,549
    You should be able to use any subwoofer in a downfiring or front firing position - the only time you should never use something in a downward firing position is like a high compliance passive radiator as "Sag" can take over.
    If anything you gain more output in a downfiring position from my understanding as gravity is not working against it as much...
    A woofer does not know where you are firing it... I am sure there are design traits that take into account the fact the floor will be reinforcing the output - if you are that concerned, fire the driver towards a wall
  • donaldfagen
    donaldfagen Posts: 30
    dvdit wrote: »
    I love my Outlaw LFM-1 EX but in the two-or-so years I've had it I've only used it in its intended orientation. If Scott is still at "The Outlaws" you should call and ask him if there would be any negative consequences to using it sideways.
    Good luck and keep us posted. You're going to be in bass heaven!
  • dorokusai
    dorokusai Posts: 25,576
    It may sound different initially but in reality it shuld be just as good as it was before. Go for it. Post some pics of the new setup.
  • donaldfagen
    Actually, someone in the Outlaw forums asked specifically about laying the LFM-1 EX on its side...
    http://ubb.outlawaudio.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=88360#Post88360
  • dvdit
    dvdit Posts: 16
    Thanks for the reply guys. Since the spot I have for the sub is at the front corner wall, I can face the driver against the front or side wall. That way it probably won't affect the design traits. I will try all positions and will post my findings.
