Question on Blu Ray
davidk0512
davidk0512 Posts: 157
edited January 2011 in Electronics
A friend of mine was looking for a Blu Ray player and asked me a few questions. During this conversation, he said he may just buy one from Best Buy, I told him not to buy one of their HDMI cables, that there are other sources much cheaper. To that, he said that he already has a HDMI cable on the DVD player that he's replacing. Well, I told him that I believe he already has a Blu Ray player. I have not seen the one he's got and I don't know the model number, but am I correct in thinking that ONLY a Blu Ray will have HDMI output? If a player is not 1080P, there wouldn't be any need for HDMI, right
David
Post edited by davidk0512 on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2011
    Nope - DVD's have had HDMI for years. In this case, I'd trust him.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • coolsax
    coolsax Posts: 1,826
    edited January 2011
    +1, I've got 2 DVD players that upscale to 1080p both use HDMI
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
    tonyb Posts: 33,072
    edited January 2011
    For a BDP though, I would have a high speed hdmi cable. Don't know how old his other one is.
  • cheddar
    cheddar Posts: 2,390
    edited January 2011
    Unless you're getting 3D or need something else in the HDMI 1.4 spec like an audio return channel, you should be fine with HDMI cables made in the past few years. I'd definitely try it before wasting good money on a new one. HDMI is pretty old technology at this point as others said. And unless you're running long cables like for an in-wall set-up, cheap cables will usually do fine.
  • davidk0512
    edited January 2011
    I appreciate ya'll straightening me out, I was almost afraid to ask the question, but I'm glad I did.
    David
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2011
    tonyb wrote: »
    As long as the HDMI cable is version 1.3a or higher, it should be all right (I guess, 1.4 for 3D support)... Monoprice cables will do the trick.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    Tony M Posts: 11,624
    edited January 2011
    ViperZ wrote: »
    That's what I found out last year.
    I also bought mine from Monoprice too.
    Now the world cable makers are uniting. If it says High speed, it's supposed to be at least 1.3.
    I.4 has more capability,Internet and such,= more cost.
  • camtah
    camtah Posts: 128
    edited January 2011
    Don't laugh. but I picked up 6' HDMI cables (RCA) from Menards for around $10 and they work just fine for me. Otherwise, Monoprice or even Tigerdirect is your best bet.
