RM7 for Surrounds - Bracket Question
I'm looking at a pair of RM7's as rear speakers for a small listening room. Due to space constraints, I'll most likely need to mount these on the back wall and angle them in toward the couch. Not ideal, I know, but this isn't a serious home theater. My question is, does the bracket with the RM7 allow you to angle left/right and how far? Is it basically a ball joint that allows you to aim in any direction?
Thanks.
Thanks.
