PSW 110 Help
Have a PSW 110 hooked up with a subwoofer RCA cable from LFE IN on sub to Subwoofer PreOut on Pioneer VSX-03TXH. Phase control set at "0", Low Pass set @ 160 on sub. Subwoofer turned on in Pio AVR with crossovers set at 80Hz for front, center, and rear speakers. Every time I turn the power on to watch TV, Bluray, etc. sub makes low rumbling noise / pop and power button turns from green to red on the back of the subwoofer. If I leave the sub plugged in and remove the sub RCA cable it still rumbles, almost static-type sound. Changed to different RCA sub cable and still does not work properly. Any help?
Post edited by landgraftj on
  • jhood2880
    jhood2880 Posts: 54
    edited February 2011
    Do you have the power plugged into a HQ Power strip?
    Living Room
    TV - Sony 60" LED KDL-60EX700
    Receiver#1 - Sony STR-DN2010
    Receiver#2 - Pioneer VSX
    Front: Monitor 70II's
    Center: CS2II
    Rear: Monitor 40II's
    Sub: PSW505
    Master Bedroom
    TV - Sony 55"
