mm12 wiring question..
Systems
How should i hook em up to my RF amp?... Positive to negative on subs, negative to negative and positive to positive?
Testing
Testing
Testing
Testing
Testing
Depends on what kind of RF amp you have and how many MM12's.
If you have two subs and a class AB amp, you'll have to either hook them up in stereo, or series the subs together. Series is hooking a + from one sub to the - on the other, then hooking the + from your amp to the open + on the sub and the - to the open - on the sub. Of course You'll only get half the rated power of the amp if you run it in stereo or series. If you have a Class BD amp... ie 500, 1000, or 1500... you would hook the subs up in parallel... + to +, - to - on the subs. Then you hook positive on amp to positive on a sub, and negative on amp to negative on sub.
"The Big C"
