200 Watts / 4 ohms sufficient for LSI9s?
paradiddle
paradiddle Posts: 41
edited January 2011 in Electronics
I'm running a Yamaha RX-V800
http://usa.yamaha.com/products/audio-visual/hifi-components/stereo-receivers/rx-v800_black__u/?mode=model
It will push 205w (dynamic) at 4 ohms. Would this be sufficient for RSi9s?
I hope the answer is a resounding NO, so that I don't make an irresponsible decision and buy a set. Haha
Cheers
Post edited by paradiddle on
    edited January 2011
    No, dynamic power ratings mean diddly squat.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2011
    No the Yamaha won't cut it.
  • bluecomet
    bluecomet Posts: 1,118
    edited January 2011
    The Lsi 9's love clean high power. Use a quality dedicated power amp and you will be surprised how they come to life. Hook it to your pre out mains. If you are using these speakers in a 5.1 system, you will need the power amp to handle the 4 ohms. The rest of the HT setup can be normal 8 ohm speakers run thru your Yamaha Rx-V800. Once you hear the Lsi series, you will want all the speakers to be Lsi speakers in your HT setup. At that point, you will need a five channel HT power amp. Trust me it happened to me. I am glad I invested in the system. I think it is awesome. Hope this helps.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
    edited January 2011
    paradiddle wrote: »
    Cheers
    What is an RSi9? Is that a Typo?
    cnh
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    A new hybrid?
    Main Surround -
    txcoastal1 Posts: 13,519
    edited January 2011
    cnh wrote: »
    cnh
    "R" is not even close "L" on the keyboard:confused:
    But anyway as others have said go 8ohm or go amp
  • paradiddle
    edited January 2011
    nguyendot wrote: »
    A new hybrid?
    Whoops!
