Removing Acura RSX Door Panels
Taylor Made
Does anyone know how to remove the door trim on an Acura RSX? The rear-side speakers were very easy to access, but I'm not sure how to gain access to the front door speakers. I see that there are 2 screws in the door but after removing those I wasn't having much luck getting the trim off.
I would greatly appreciate help!
Thanks!
Thanks!
Post edited by Taylor Made on
Should just be screws and clips. There is a tool you can use on the clips, it is like a 'U' shaped screwdriver. Usually, you remove the screws, go around the outside of the panel and 'pop' these plastic clips, then lift up and out (towards the roof).
Hope that helps, It should not be any more complicated than that.
These clips are, well, crap, I'm at a loss to descirbe them... They are usually a yellow-white, and screw shaped. Located about 6 to 8 inches apart, about 1 inch into the panel (from the outside).
Good luck....
RCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I have no idea how to get the door panels off, but the RSX sounds like a neat little car. How do you like it? (Sorry, not trying to change the subject....)
Hey,
check out http://forums.clubrsx.com/, I bet they have some threads about door panel removal.
~JB -
Thanks for the info. The guys at forums.clubrsx.com did have the answers to all my questions and now I've found a great new forum!
Sweeeeeeeet. How do like that car? Did you get the type-S?
~JB
