Lost post, but need some guidance.
KaosTsoc
KaosTsoc Posts: 372
edited January 2011 in Car Audio & Electronics
Ok. So, im looking at sub amps. Here are my two top choices so far.
Alpine MRP-M2000
Specs:
Crossover: 50-200Hz
EQ (Equalizer): Center Frequency Adjustment 30-80Hz, Gain 0-12dB
Subsonic Filter: 0, 15, 30Hz
Power Requirements: 14.4V DC (11V to 16V)
Frequency Response: 20Hz - 200Hz
Speaker Impedance: 2 - 4
Signal to Noise: 75dBA
RMS:
Per channel into 4 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 1500Wx1
Per channel into 2 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 2000Wx1
General Info:
Amplifier Type: Class-D
Channel Design: Mono Amplifier
Thermal Control: Thermal Management Control
Power Supply: DC-DC PWM Power Supply
Power Supply Design: MOSFET
Board Circuitry: Globally Modulated Design
Current Protection: Automatic Over-Current Protection Circuitry
Power Indicator: Top Mounted Blue LED Power Indicator
RCA Output: Gold Plated RCA Input Connector
Speaker-Level Inputs: Speaker Level Inputs
Crossover: Adjustable Low-Pass
Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals
Board Design: Dual Sided Glass Epoxy PC Board
Gain Control: 2-Position Gain Setting
Foot Print (WxHxD) in: 20-1/4'' x 9-7/32'' x 2-23/64''
And of course Alpine is CEA-2006 Compliant
Massive Audio N4-Mono Block Amplifier
Specs:
RMS Power 2000 x 1
PEAK Power 4000 x 1
RMS@2Ohms 1000 x 1
Bridged RMS N/A
Min Impedance 1 Ohm
Min Impedance Bridged N/A
THD >1%
S/N 100dB
Max Voltage 15v
Max RCA Voltage 5v
Freq. Responce 10HZ-220HZ
LPF 40~220Hz
SubSonic Filter(HPF)10~50Hz
Low voltage protection
ShortCircuit Test @ max power
Overheat protect temperature Protect at 80C / 176F
Minimum Load 1Ohm
THD at 4Ohm load 30% Rated Power <0.3% At 1Ohm <1%
Dimensions 13.4" x 5.5" x 2.1"
And, yes this amp is also CEA-2006 compliant.
The head unit that will be driving they system is the (thanks to Dskip):
Pioneer Deh-P8600MP
Specs:
Supertuner IIID
24-bit Burr Brown
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer 13-Band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
Advanced Sound Retriever (ASR)
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
Subwoofer Direct Control Key
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (4V), 100 ohm
Ok, so aside from alpine haveing the name recgonition. Im looking to get some feed back from you guys on this please, and thank you. Now if you have had a chance to look at these amp you will see that the Massive audio amp does not offer a whole lot of tuning features, and is pretty straigt forward. The alpine offers more in that area, but since the HU as a good eq on it already. Does it really matter to have those features on the amp? Also do to size restrictions im thinking of the N4 amp a little more. Dont get me wrong, I still partical the alpine, just because the RMS setting is pretty much where I want to be. However the massive audio will do the same, but down to 1ohm. As for price they both are at the same price range. As for power management I have that covered, so thats good. So, let me know your thoughts/views.
Thanks.
2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
Post edited by KaosTsoc on
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2011
    Get the Alpine and tune with the head unit.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    Thanks mac. If you dont mind me asking. Why did you side with Alpine?
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    I understand that alpine is well a big name, and they do make good products as well. However with massive audio they also get good reviews as well, and overall they are positive. Also this question still stands cause im not sure if it matters or not. Since the HU as a good eq on it already. Does it really matter to have those features on the amp?
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    Sorry about the subject line on here. It should have been long post, but need some guidance.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    This is very ture. But like I said as for MA that have a good following, and they have all said that for such a small package it produces a bunch of clean power. Im glad you chimed in on here, and gave your thoughts. So, i guess it is safe to say that haveing the tuning option on the HU would fine either way, and that the tuning features are just more of a bouns in my case, and would be a for lack of a better double filtering.?:confused: I can see where having all those tuning options on the amp if lets say I kept my current CZ500. This HU does not offer that much in tuning features so, I would then lean on the amp to help filter out the rest right..??:confused:
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • exalted512
    exalted512 Posts: 10,735
    edited January 2011
    KaosTsoc wrote: »
    Because he's biased:tongue:
    The 8600 was plagued with problems though. I'm a Pioneer guy but was never fond of that unit.
    -Cody
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    I kind of figured some of the opinions on would be biased, just do to the fact that alpine well....is a good brand, and makes good stuff. MA however is not really known. So, yeah.. Well I hope the HU does not act up, if it does, then I will see about getting it fixed or what not. I mean that HU is no longer available. If worse comes to worse, I would get a 13 band external eq, and do it that way.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • MacLeod
    edited January 2011
    Yes Im biased. Ive used over a dozen different Alpine amps and head units over the last decade, and theyve all performed flawlessly. Cant beat that. So I choose them for their build quality.
    Not saying the Massive Audio isnt a good amp - I know next to nothing about them so I cant say one way or the other. But I know what youll get with Alpine, and thats a good quality piece of gear.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    Thanks mac. That makes sense. Well now that you say you have been using their stuff for a while. Have you ever used the M2000? If so, what do you think of the size? I have not seen one in person yet, so it is hard to tell.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    Reported ^^^^
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • MacLeod
    edited January 2011
    Lots of spam around here lately.
    I haven't tried the new Alpine amps. My last amp from them was the old V12 line with the half silver covers. Loved those. I also used a couple of their V Power amps that are the best entry level amps IMO.
    The stuff I haven't used, I've talked to a lot of guys in the lanes that do run them and they all seem to be pretty satisfied.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited January 2011
    The reason I asked is, because I have some limitations on how big of an amp I can get. Aside form having to a mock up of the amp to see if it fit. I was hoping to get a better idea.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
