Not sure what's next
falconcry72
falconcry72 Posts: 3,580
edited January 2011 in 2 Channel Audio
I am at a good place with my 2 channel system, and I'm not sure what the next step is. Here's what I've got going:
Source: computer>SPDIF out
DAC: Parasound DAC 2000 Ultra
Preamp: Parasound p/ld 2000
Poweramp: Parasoud HCA-2200ii
Speakers: SDA-1C's (for rock, fusion, harder jazz etc) Magnepan MG-12's (for softer jazz, acoustic stuff, etc.)
Cables: MIT AVT-1 IC's, MIT AVT-3 speaker cables
I'm looking to spend less than a grand. I'm not sure what the next step is that will make a big improvement. I'm pretty happy with everything. I'm thinking either tubed preamp, or new speakers. As far as speakers go, moving up the SDA chain is not going to do it for me, and I don't think moving up the Maggie chain will either. Ideally I'd find a speaker that does rock better than the SDA's and acoustic music better than the Maggies, but I'm afraid that a speaker cabable of those things may cost big bucks. Suggestions?
Post edited by falconcry72 on
    treitz3 Posts: 19,946
    edited January 2011
    If I were you, and I'm not, I would work on acquiring a different source. Therefore, that is my suggestion to you.
  • Jetmaker737
    Jetmaker737 Posts: 1,103
    edited January 2011
    There's no guarantee of success when you try something different. But if I had your system I'd try a tube pre. But you will need to bump your budget a little north of a grand in order to consider more options.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2011
    Are your 1C's x-overs modded? Room treatments? Introduce some tubes in the mix...several ways to improve on what you already have...my 2c.
  • falconcry72
    edited January 2011
    treitz3 wrote: »
    I have to use my computer as a source because I absolutely love the convenience and can't go back to cd's. If there is a markedly better way to use my computer as a source, then I'm all ears, but I'm not going vinyl or back to cd's.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2011
    If you are in a happy spot - then rest for a bit - enjoy the music, use your money to buy some nice wine and enjoy the moment!
    edited January 2011
    Fair enough. That's your choice and I can respect that.
    In that case, I would recommend an X-over/tweeter upgrade on the SDA's and looking into some room treatments, if the wife or significant other wouldn't disapprove.
  • falconcry72
    edited January 2011
    Erik Tracy wrote: »
    I think you're right.:smile:
  • falconcry72
    edited January 2011
    treitz3 wrote: »
    ...I would recommend an X-over/tweeter upgrade on the SDA's and looking into some room treatments, if the wife or significant other wouldn't disapprove.
    Tweeters are done. Doing the crossovers would help, but I don't think it would get me where I want to go.
    Room treatments is a great idea. My only signifigant other is my dog, and he's pretty open-minded in terms of decor.:biggrin:
  • falconcry72
    edited January 2011
    bump.
    Still looking for suggestions. Speaker suggestions would be helpful; I'm looking for something that will bridge the gap between the SDA's and the Maggies.:smile:
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2011
    This maybe isn't pertinent and I personally haven't done this... but you could buy an EICO ST-70 integrated 35wpc tube amp and a pair of vintage high efficiency speakers on your budget.
    And because you're buying them vintage at market value, if you don't like them you can always sell them for what you paid for them, essentially.
    -- wayne --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • falconcry72
    edited January 2011
    wayne3burk wrote: »
    -- wayne --
    That was so far from what I was looking for, but so perfect. Thanks for that, I was hoping to get a suggetion I hadn't already considered. :biggrin:
    It totally makes sense to try a completely different style rig and compare. Time to research... thanks again.:smile:
  • jm1
    jm1 Posts: 618
    edited January 2011
    Room treatments so you can accurately evaluate your current components.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
