best components for polk momo?
Systems
i am goin to upgrade my highs for my car.
i want to know which components are the best of polk momo.
Is it the MM6 or the MM465???
Are there some differences???
Testing
Testing
Testing
Testing
Testing
the MM6 is the 2002 / 2003 model of the MM465 -- same deal. different cosmetics.
the main difference, from what others have posted, is that the crossover casing on the MM6's is more difficult to get apart (to install).
so i'd say just get whichever ones you can find the cheapest new, or whichever's cosmetics u like best.The Artist formerly known as PoweredByDodge -
also, the crossovers for the mm6 components are much smaller than the mm465s, i put my crossovers on the kick panels but i would not have been able to if i had the mm465s
-Cody -
i wished these fit in my 4runner
ya, well ... i wish i had 8's up front and i dont
i wish i had subs in my truck at all....
-Cody -
i wish i was a baby bumblebee, then my mom would be so proud of me.......
I wish I had more money that Bill Gates.
That way I could buy Microsoft and make them actually make a product that worked properly rather than worry about Joe Blow stealing it.
I'd also be able to buy a Ferrari, one for every day of the week...with matching underwear!Expert Moron Extraordinaire
... i'd buy out mtx, make them build Blue Thunders again, and have underwear that said " Feel the Thunder " across the front.
heh heh heh hehThe Artist formerly known as PoweredByDodge
