Would these 2 turntables be considered an upgrade to what I already own?
gfong
gfong Posts: 1,079
edited January 2011 in 2 Channel Audio
I own a Audio-Technica LP120 USB turntable and was wondering if either of these 2 tables would be an upgrade or make a noticable differance in sound reproduction?
(I can get either table with 20% off of the listed price.)
Pro-Ject Audio Debut III Turntable with Ortofon OM-5E Cartridge $399.00 (many colours)
Music Hall MMF 2.2LE with Tracker Cartridge $499.00 (white/red/black)
My AT 120 is starting to annoy me as it hums when the arm gets closer to the center of the record. I have aligned everything and have tried two different cartridges. Cables are attached and can not be changed out.
Anyway I am sure I could deal the AT for a few bucks if I did end up going with either of the 2 tables listed.
Most reviews say the Pro-ject is an great entry level table and they say that the Music Hall 2.2 has a better tone arm then the 2.1!
Thanks.
  • quadzilla
    quadzilla Posts: 1,543
    edited January 2011
    Both would be a major upgrade.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • raffi
    raffi Posts: 114
    edited January 2011
    I don't currently own a TT but QZ is right. If I could get either one of those at the price listed less 20% I'd be all over it...good luck.
    2 channel rig: MMF 2.2 turntable, Adcom GFP-715, Adcom GFA-555, Adcom ACE-515, Carver M-1.0t, Denon 5900 CD/SACD, SDA-SRS 2.3s (Zardoss modded), AQ Diamondback & King Cobra IC's and AQ Type 4 speaker cables
    HT rig: Panny 50" G20 plasma, Directv DVR, Insignia BRD/DVD/SACD/DVD-A, Denon AVR-890, Fronts: Polk Monitor 70's, Rears: Deftech Mythos Gems, Center: Polk CS1, Sub: Polk PSW-505
  • gfong
    gfong Posts: 1,079
    edited January 2011
    I think I will be going with the Music Hall MMF 2.2LE Ferrari Red turntable. Going downtown tomorrow to possibly have a listen to the Rega and the Pro-ject. I do not think I can see or hear the Music hall in my area.
    Thanks for the information.
  • markmarc
    markmarc Posts: 2,309
    edited January 2011
    Take a look at the Rega RP1, I checked out the Project and Music Hall you mentioned and ended up with the RP1.
    Former Staff Member TONEAudio
    2 Ch. System
  • raffi
    raffi Posts: 114
    edited January 2011
    Another good suggestion by markmarc...the RP1 along with the Debut III and MMF 2.2 are the only 3 turntables that I'm considering, as I'm looking for good performance/reliability/affordability. From what i've researched, you should be in good shape with any of those 3.
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    Any one of the three would be a huge upgrade...money money being on the Rega.
    BDT
  • polkapolka
    polkapolka Posts: 145
    edited January 2011
    I would suggest one more, the Project 1.3 Genie http://www.project-audio.com/main.php?prod=rpm13&cat=turntables&lang=en for information
    and this, Needle Dr. site... http://www.needledoctor.com/Brand-Stores/Pro-Ject_2
    It is $499, and is supposed to be quite competitive within that price range. If you can see/ listen to this one, it wouldn't hurt.
    Good luck with your purchase,
    Matt
    Mitsubishi 60" HD LDP
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
    Pioneer BDP-51FD Blu-Ray
    Polk Fxi3s for surround.[/SIZE]
  • gfong
    gfong Posts: 1,079
    edited January 2011
    I started a new thread with my new turntable addition. Thanks again all, really appreciate the advice/assistance. Thanks, Greg Fonger (gfong)
