Tweeters
Drevlin
Drevlin Posts: 23
edited January 2011 in Vintage Speakers
Hello everyone. I have posted for this issue in the past and have worked on it off and on. My SDA 1C Left channel has tweeter issues. The best I can describe it, is that the tweeters will cut out completely when playing at any volume during a quieter passage and kick back in usually when the bass comes back in.
-there is no poly-switch, it has been completely bypassed
-I have checked all connections including the X-over
-I have tried swapping tweeters between speakers
I am basically completely out of ideas and am trying the forum one last time in hope there is a little more help out there.
thanks
System:
HK680i
HK AVR 254
Carver TFM-35x
Carver CT 6
Samsung 37" 720p
AAL Speakers (modified, unknown Model)
Polk SDA 1C (Upgraded X-overs)
Polk Monitor 7
Roland DM-20 monitors
Post edited by Drevlin on
  • Drevlin
    Drevlin Posts: 23
    edited January 2011
    sorry for a double post, I am going over the xover on my left channel
    On the SDA 1C x-overs what is the purpose of C4 marked on the Board?
    System:
    HK680i
    HK AVR 254
    Carver TFM-35x
    Carver CT 6
    Samsung 37" 720p
    Polk Monitor 7
    F1nut Posts: 51,776
    edited January 2011
    You have a loose connection somewhere in the chain. Could be on the board, could be the wiring harness, could be the connection at the tweeter, could be the actual voicecoil.
    F1nut Posts: 51,776
    edited January 2011
    C4 is a 750pF silver mica cap. It is used as a bypass cap to the 12uF at C3. If you upgrade the caps, remove and do not replace C4 with anything.
