New sub, ext. amp, or new fronts for more midbass/range
vadang
vadang Posts: 101
So the OCD has kicked in, I have only been on this site for a week or two and I am already an addict. Now I can't stop thinking of buying stuff which is bad, because I'm already broke :)
Here is what I have managed to nab off of craigslist for my budget HT in the last week or so:
-Pioneer VSX-9040TXH
-CS400i
-RT800i x 2
-PSW10 & Athena AS-P6000 (replacement amp, original died) these I basically got for free
-Room is approximately 20x15 w/ 10' ceilings.
-90% movie 10% music listening
-I only plan on running 3.1, no rear surround
I've done the MCACC, played with speaker positions, interchanged the subs, tried both subs simultaneously, etc etc but I really feel like I am lacking a good solid midbass/midrange punch. Front stage is set to small and I've changed crossover points from 50-80 hz and still not thrilled. I've tried setting them to large, but then the receiver automatically reduces the sub output tremendously.
So finally my question:
Which item would make the most impact in the $200-300 range:
[1] new sub, I was thinking of a BIC F12, PA-120, or equivalent polk.
[2] Ext. 3 channel amp (recommendations for my budget? used is ok)
[3] Get beefier front stage (M70s? used RTi8? RTi10? or some other pre-powered fronts)
I know I need a better sub, but I can live with what I have for now, if getting an ext amp or new fronts would give me a better midrange.
Thanks for any help!
Living Room:
Paradigm Cinema 330 x 3, Pioneer 9040TXH
Media Room:
RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM
Post edited by vadang on
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2011
    Start with a better sub. Look at the Polk DSWPro 400 or 500. Once that is in place, start saving more money for a 5 channel amp.
    tonyb Posts: 33,065
    edited January 2011
    Better sub, your room is pretty big for the psw10 to pressurize. Try taking the sub out of the mix all together,set fronts to large and sub to "no" and play your fav. test cd and see what happens. Also check your speaker levels, sometimes the auto calibration sets them pretty low. Return them to 0.0.
  • vadang
    vadang Posts: 101
    edited January 2011
    I've run MCACC a few times and it set the LCR anywhere from +2.0 - +3.5, so I just left them alone.
    I guess I am on the hunt for a sub now....thanks!
    Living Room:
    Media Room:
  • djperez81
    djperez81 Posts: 388
    edited January 2011
    I would definitely upgrade the sub i first started out with a psw 10 and i thought it sounded ok but when i got my velodyne it was on another level. It had nice clean deep bass. Good luck.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
