There used to be box plans on this site....
Systems
Systems Posts: 14,872
edited August 2003 in Custom Fabrication
Several years ago, there were plans for a compound bandpass enclosure for two 10" db10 subs facing each other and wired out of phase.
I built a box according to those plans but have since removed the subs.
Will any of the new 10" subs work in that enclosure? Particularly the GXR 10"?
Does anybody remember the box plans that I'm talking about?
Can the site administrators dig this out of their archives?
Thanks.
My email is mroberg AT i-p-g DOT com
Testing
Testing
Testing
  • Systems
    edited July 2003
    I'll have to get you that info when I get home tonight.
    Thanks in advance for helping me out.
    Testing
    Testing
    Testing
  • Systems
    edited July 2003
    Okay, here are the numbers:
    The larger compartment with the ports is 0.76 cubic feet.
    It has two ports that are 3" diameter by 5.25" long each.
    The smaller cmpartment is 0.54 cubic feet.
    This thing put out a lot of bass but I had to remove the subs to be used elsewhere.
    Any help would be greatly appreciated.
    Testing
    Testing
    Testing
  • Systems
    edited August 2003
    Thanks for the help, Kim.
    I'm not sure I understand the graphs properly, but it looks like any of those three subs will work fine in this enclosure.
    Am I making a mistake?
    Also, will putting in two subs facing each other and wired out of phase help the bass output or will I be hurting the performance of this sub?
    Do you have any idea if this sub will sound musical with the GNX or just plain boomy?
    Thanks fro your help.
    Testing
    Testing
    Testing
