Biwire
edited January 2011 in Speakers
Looking at an Mit avt single cable for my polk lsic center. The cable (mit avt bw3) is biwire. I dont want to biamp my speaker, so if I just connect all four wires into their respective binding post all should be okay, right? I wont experience sound quality, or other ill effects of using this cable?
LIVING ROOM:
Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
Post edited by angelsfann02 on
Welcome!
    edited January 2011
    You will be fine.
    Ben
    edited January 2011
    Thanks Ben.
    LIVING ROOM:
    edited January 2011
    No problem:smile:
    Ben
    edited January 2011
    Just be sure that you remove the jumper between the two pairs of binding posts.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited January 2011
    Holy crap why? Glad you mentioned it.
    LIVING ROOM:
    edited January 2011
    It won't hurt anything to run them with the jumpers in place, but if you have all the holes filled you should remove them.
    Ben
    edited January 2011
    + 1 on the jumper removal
    edited January 2011
    Do the Mit avt biwire speakers have an internal crossover or something in that "box" attached to each cable. I think that I am misunderstanding whats in the "boxes". Thnks.
    LIVING ROOM:
    edited January 2011
    it is not a crossover in the box. If you speakers are bi wire capible, the crossover is in the speaker itself. The jumper just joins the highs and lows to the internal crossover.
Welcome!
Welcome!
