Battery terminals
KaosTsoc
Ok. I just want to make sure that I can do this. I going to be working on my power for the audio system. Im looking at getting these terminals
http://www.tsunamionline.com/BT703.html
they are plain, and simple. This is also just for the positive side. My question is this. Since this is a four position 1) 0g 1) 4g 2) 8g if I want to add say another 4g wire to power my second amp would I be ok, provided I get the correct threading to change the screw that holds the 4g in into a set screw as well. Kind of like this one.
http://bicostereo.com/index.php?act=viewProd&productId=4899
As you can see, not only does the screw hold the wire inside the terminal, but will also act as a set screw for another wire with the ring treminal attached.
Im trying to give a power line for each amp seperatly, and trying not to use a distro block. It will all be fused of course for protection as close to the battery as well. So, any thoughts or suggestion or experiance notes welcomed.
Thanks.
Thanks.
2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
