Anyone heard these ?
begbie
begbie Posts: 630
edited July 2003 in Speakers
Mirage Omni series. Pretty funky looking. Almost alien like. The woofer and tweeter each points up and reflects off a mirror to give a 360 degree surround effect. Rave reviews i've read and some good followers at the avsforum website.
I actually just had a demo of them but unfortunately couldn't do an a/b comparison with a traditional speaker. The speaker sounded fine . It was certainly different sounding, I wasn't blown away but then I never had a proper demo to convince myself.
What do you guys think of speakers that try to emulate a surround effect such as definitive technology, mirage, or I believe even the Polk SDA ?
Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111
Post edited by begbie on
  • Ceruleance
    Ceruleance Posts: 991
    edited July 2003
    firing up into a deflector isnt a new concept, but it's usually something done on a much smaller scale (i.e. computer multimedia speakers)
  • begbie
    begbie Posts: 630
    edited July 2003
    anyone else with experience on these speakers or similiar to the ones i mentioned?
    What do you think of "natural?" 3d sound? Would you rather an enveloping sound stage that's very real or one that's more forward ?
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
    VR3 Posts: 29,428
    edited July 2003
    I LOVE DEF TECH!
    They are completely awesome. A definete *wild* soundstage that fills in the entire room. I love the sound! If I could buy Def Tech, I would! They have the coolest sound I have heard. I would take their soundstage over Wilson Audio X-1 ANYDAY! Def Tech is AWESOME! Their TOTL does
    13hz-30khz. 18 inch sub in each tower, 1000 watt amp in each tower. Bipolar design (4 woofs, 2 tweets per speaker). It has absolute carlity from the loudest to the softest of volume. For music - they are simply UNREAL. Completely awesome design. I wish I had the $$$$ to get Def Tech! Just awesome stuff! IMO of course......
