Centre Channel
csnoff
csnoff Posts: 34
edited January 2011 in Speakers
Ok so I have been piecing together my home theater bit by bit buying speakers always on sale, and I have tried to get things at cost almost always. When I started out I bought a Klipsch RC-52 to go with a bunch of random speakers. Since then I have upgraded to include Monitor 70's fronts, M10 Surrounds (soon to be replaced), and just purchased some FXiA4's as rear surrounds, I know that the idea is to match brand for brand, so with that being said do you think it is worth it for me to go out and replace the RC-52 with say the Polk CS1 or even the CS2???
How does the CS2 sound in comparison to the RC-52 (I know that this is a very subjective question) but some ideas as to what I should go with?
I currently have the Yamaha HTR 6190, I would think that this should be enough to run the current setup.
Post edited by csnoff on
    EndersShadow Posts: 17,596
    edited January 2011
    csnoff wrote: »
    Yes it is, and suggest the CS2 over CS1.
  • kdarshan
    kdarshan Posts: 11
    edited January 2011
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2011
    I have the CS1 and like it, but to match the 70's better I'd definately go w/ the CS2. I've not heard the Klipsch center but would imagine you'd be better off w/ a front stage that timbre matchs your LR so the sound would be more natural during movies as a sound goes across from one side of room to another. Just my .02c
  • csnoff
    csnoff Posts: 34
    edited January 2011
    So is the CS2 the matching centre for the Monitor line then?
  • B Run
    B Run Posts: 1,888
    edited January 2011
    csnoff wrote: »
    Yes it is. The Klipsch center is a good one but sounds very different, I think you'll like the improvement of your fronts all being timbre matched.
  • TNHNDYMAN
    edited January 2011
    yes the CS1 has two 5 1/4 drivers and the CS2 has two 6 1/2 drivers the same as your 70's.
