Need advice on 5.1 setup?
Right now I have Polk RM85 as front speakers. How much distance should there be between the 2 I have about 4 feet separation now,(50 in Plasma in the center). Any sugestions?
Racfan9
Racfan9
Post edited by Racfan9 on
I have my 2 RTiA3's resting on either side of a 15 foot mantel; which probably means I have about 13 feet in between the two. I don't have any problems so if you're thinking about increasing the distance I don't think that would be a problem.Home Theatre
Receiver: Onkyo TX-NR808
Fronts: RTi A3
Centre: CSi A6
Sides: FXi A6
Rears: OWM 5
Subwoofer: TBD -
Racfan9
I also have a 50" plasma but with Monitor70's as fronts. They are spaced out 36" to either side of the plasma sound really good.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
