CJ Upgrades
chargerman426
chargerman426 Posts: 419
edited February 2011 in DIY, Mods & Tweaks
Hey guys I'm think about doing some upgrades this year on my CJ PV-11 tube pre amp. I want to upgrade the tube sockets,RCA jacks, Caps, possibly the resisters, and adding an AC socket. I have been reading all of the threads about caps and I'm just a little confused on what caps to replace. Do I replace all of the caps or is there few that I should replace? Should I change them all but buy nicer ones in a sertent spot as they will make a bigger difference? I also have the same questions about resistors. Any help would be greatly appreciated. I have attached a pic of the inside of the pre for reference.
If life had more tubes it would be a lot smoother.
  • george daniel
    george daniel Posts: 12,096
    edited January 2011
    IIRC, the output coupling caps are the ones that will give you the better bang/buck upgrade.
  • chargerman426
    edited January 2011
    I wanted to spend let then 500 for the caps so I was thinking that I could go with sonicap gen1 for everything to keep cost down and maybe getting some of the sonicaps platinum for the one that would make a difference.
  • chargerman426
    edited January 2011
    george what does IIRC mean and how can I tell which caps are the output coupling ones?
  • george daniel
    edited January 2011
    If I Remember Correctly--can you take a couple more pics of the insides,,looking down?
  • george daniel
    edited January 2011
    A schematic might help-- and let Fred look at the pic or schematic and you'll know in a sec.
    I think your output coupling caps are 2.0 uf,,
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    I'm guessing(need a schem to be sure) the black SCR's and or white film caps near the center rear directly behind the tubes are the output coupling caps.The film cap count is very high,I only see one electrolytic so CJ obviously doesn't like to use them even for power supply filtering duties.
  • chargerman426
    edited January 2011
    CJ said they use polystyrene or polypropylene (I can't remember) though the entire pre.
  • chargerman426
    edited January 2011
    schematic is below
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    C26 and C27 in parallel are the ouput coupling caps so likely the two I mentioned in the previous post.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Maybe a bit of both,the SCR's are likely Polyprops they are the guys that manufacture Solen's fast cap for them.
  • george daniel
    edited January 2011
    ^^^^^^^^^^^^^^^^told ya ^^^^^^^^^^^^^^^^^^^^^
    Fred,, how long have you been doing this? :smile:
  • chargerman426
    edited January 2011
    So would it be an upgrade if I go with the Sonicap Gen1 or the sonicap platinums?
  • chargerman426
    edited January 2011
    Also the C26 caps are .15uf/220V (white caps) and the C27 or 2.0uf/250V (black caps). C22 and C23 are the same as C26 and C27, so does that mean C26+27 is for the right and C22+23 is for the left?
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Started in around November.:biggrin:
    Only one channel(right) is shown in the schematic.C22 and C23 are the output coupling caps for the phono section.I would omit the .15uf bypass caps when installing a premium 2.0uf film.I believe George has tried a number of good caps in his own tube equipment so can recommend a suitable upgrade.
  • chargerman426
    edited January 2011
    Ok I only posted the schematic part. I got the parts list to so I just assumed C26+27 were for the left. Should I replace the other caps or any resistors?
  • george daniel
    edited January 2011
    I would replace the caps that Fred mentioned with a flavor that you like/prefer,, as for the others,if they are good,,I'd leave em alone.I think that you are gonna get the biggest bang/buck with the output coupling caps,,and leave the bypass caps out,,how much money you wanna spend on caps?
  • chargerman426
    edited January 2011
    I was looking at less then 500 but that is what I was thinking for the whole pre. So if I'm only doing 2 caps less then 100 or so.
  • chargerman426
    edited January 2011
    I have seen some nicer caps that come in 2.2uf but not 2.0uf is this a problem of I take out the .15 bypass cap?
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Yes you can increase the value,but decreasing it will affect the bass response how much depends on the input impedance of the amp it's driving.
  • chargerman426
    edited January 2011
    Thank you guys for all your help. I think I'm going to go with the below cap in 2.2uf. Let me know what you think.
    http://www.soniccraft.com/mundorf_silver_oil.htm
  • chargerman426
    edited January 2011
    Bump. Any input on that cap?
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Sorry I have no experience with Mundorf so can't comment on it's SQ but it's value would be suitable.
  • chargerman426
    edited January 2011
    Cool, thanks for all of your help man. If anyone has any suggestions about a good cap that would be under 100 bucks for a pair that would be helpful. Also, would it help to upgrade the tube sockets over the stock ones?
  • chargerman426
    edited January 2011
    Ok I think I have picked out all the caps I want to use. I was rolling some tubes and noticed the left side was microphonic out of the left channel. I switched tubes and the problem did not move. I think its the tube sockets as they are 20+ years old. Any suggestions on a good socket. I wanted to use a Teflon socket but I cant find it in a PC size.
  • george daniel
    edited January 2011
    I just sold a pair of Mundorf SIO 2.2 uf's.
  • chargerman426
    edited January 2011
    Do you have anything else in a 2.0 or bigger?
  • chargerman426
    Hey I just did installed the new caps and I have a problem. I can barely hear anything out of my speakers. If I turn the volume up 3/4 of the way up it just sounds like they are just whispering in my speakers. Any help?
  • george daniel
    did you check your solder connections?
  • chargerman426
    Yeah I checked before I put the bottom back on. I checked for resistance with an ohm meter.
  • chargerman426
    Hey guys I fixed it. I had two bad solder joints in the output caps. Goes to show what sleeping on it will do for your soldering skills :)
