changing from csi 30 to???
john Jarvis
john Jarvis Posts: 18
edited January 2011 in Forum Testing Area
just recived my rti a7's last week. i have a csi 30 center was wondering about the csi a6 or a4. will there be a big change going with the a4. or should i just go big and get the a6. size is not the big of a deal.
Post edited by john Jarvis on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited January 2011
    Go big or go home.
    The CSi is closely matched (but not perfect) to your RTiA's. If you get yourself an a4, you'll be making more of a lateral move.
    CSiA6 is my suggestion. Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    I'd go with the CSiA6.
    A bigger center channel is always a good choice. The center channel is essentially the most important speaker in a HT setup, since it carries nearly all of a movies dialogue, and generally around 60% of a movies soundtrack. It's a crucial speaker and you want it to be able to perform as well as it can.
    Especially since you're using the A7's, which are a larger floorstander. The A4 would still sound great, but would be slightly more overshadowed by the A7's than the A6 center would be. If the size and the additional cost aren't of concern, my recommendation would definitely be the A6.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • john Jarvis
    edited January 2011
    thanks for the replies. Going to the a 7's from the rti-38, what a big change. I have a yahmaha rx-v663 7.2 reciever. I was wondering how I could use rti-38's in my setup now as present sound? Or just put in my bedroom?
  • kawizx9r
    edited January 2011
    You can keep the 38's and put them on surround duty. Timbre-matching is important for HT, but that mainly pertains to the front soundstage.
    Try it, and if you like it then keep it. If you don't, might I suggest some FXiA 4/6's :wink:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • john Jarvis
    edited January 2011
    well i have fxi 30's now so i think i will stick with them. but i did order the csi a6 today. can't wait for it to to get here!!!!
  • kawizx9r
    edited January 2011
    You'll love the A6 :smile:
    Btw, just noticed that this was posted in the Testing part of the forum. None of our posts count :eek:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • john Jarvis
    edited January 2011
    i guess i don't know how to post else where not even sure how i got to the testing part
    pitdogg2 Posts: 27,522
    edited January 2011
    die spammer die
