CD Tray Lube?
  • george daniel
    george daniel Posts: 12,096
    edited January 2011
    Jesse,, yes,,in fact thats mainy what it's used for.Although I did use some on a squeaky door hinge a few years ago, now if the door is not completely closed,,it swings open on it's on without a sound. I'll see if I can get uoi a can,,or you can use mine--it's a spray,,I've had a can for 27 years,,it's that good.
    F1nut Posts: 52,002
    edited January 2011
    Ok, I'll call you.
    F1nut Posts: 52,002
    edited January 2011
    My 1 ounce container of Moly-Kote EM-30L arrived the other day, but I've been too busy to try it until today. I applied a very light coat to the outer edges of the tray rails and pressed the close button. I'm impressed, no more noise when the tray opens/closes.
    I also noted that this 1 ounce container has enough in it to last me a couple of lifetimes.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    Thanks F1. Noted:smile:
    Ben
  • ben62670
    edited January 2011
    Jesse where did you purchase it from?
    Ben
    F1nut Posts: 52,002
    edited January 2011
  • ben62670
    edited January 2011
    Wow thanks. That is certainly cheap enough!
    Ben
  • smglbrth
    smglbrth Posts: 1,499
    edited January 2011
    Thanks for the above link! Just bought some myself...
