loudnes control
thesurfer
edited January 2011 in Speakers
Local hi fi dealer says you shouldnt use loudnes control, to add db,s what say you folks,, think hes talking recievers,,,
Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
«13
    edited January 2011
    Tone controls are evil, that includes the loudness control.
  • thsmith
    edited January 2011
    What is loudness control ? J/K, I have some old receivers that have it but never use it. New stuff has no tone or loudness controls. A freind of mine that repairs audio equipment disbales all that stuff.
  • Libertyc
    edited January 2011
    Loudness was good in the car back in the day. My preamp has volume and a source switch.
    edited January 2011
    Don't use it or tone controls. None of my gear has tone controls. They are evil and completely useless in correcting issues which are beyond the scope of typical tone controls.
  • Erik Tracy
    edited January 2011
    thsmith wrote: »
    If I can remember that far back....as I recall the Loudness button is meant to be used at low volume settings that boosts the low and high end of the audio spectrum - something to do with human hearing being less sensitive at lower voluems to those ends of the audio spectrum, so at low volumes the Loudness button compensates for this to 'even out' the tonal balance.
    Newer AVRs have auto-calibration features - so if you run those, then aren't you in a sense using 'tonal controls'?s
  • Libertyc
    edited January 2011
    Yes Erik that is exactly what the loudness button did. It was for low volume and boosted the highs and lows. It sounded good especially in car audio with the older cars and all that road noise.
    edited January 2011
    No loudness; no tone controls. They are evil, indeed - more harm than good relative to my ears and tastes.
    The living room hifi no longer includes an active preamp; only a source selector switch and "trimmer" volume adjustment pots on the sources.
  • Erik Tracy
    edited January 2011
    Libertyc wrote: »
    Practically all 'vintage' receivers and int amps that I saw or owned had them too.
    In my younger years of ever questing for recreating concert levels in my abode, the "Loudness" button remained in use.....sad...yes....I confess....I have grown wiser... :biggrin:
    edited January 2011
    If your gear is good enough no loudness control is needed for low level listening. HT AVR's are a different catagory completely and their auto-calibration is a type of tone control. I would never, nor do I critically listen to music on an HT system beyond concert DVD's which are explicitly mixed to be used in a HT setting vs. a critical listening 2ch set-up.
  • [Deleted User]
    edited January 2011
    Anybody remember Fletcher-Munsen?
  • Erik Tracy
    edited January 2011
    Had to google it but when it came back with "Equal Loudness Contours" - yup...
    edited January 2011
    Yep, but I've found with my current gear that even at low level, the resolution is excellent. Even my inexpensive single ended tube integrated's sound wonderful at low levels. But. not all gear does.
    cnh
    edited January 2011
    Hmmm. I'm going to have to think about that. Because most gear I've heard loses something at low volumes unless you're close enough and you have sound-proofing in your room. Either that or my hearing is just gone, gone, gone.
    I don't doubt that some gear may be good at any volume but those are not the majority in my, admittedly, more limited experience.
    cnh
  • steveinaz
    edited January 2011
    Yamaha used to use varible loudness on their pre's, pretty cool for the time. You set your volume control to near max listening position, then used the outer loudness "ring" to control volume. I though it was pretty innovative (c-60/c-80; c-65/c-85 pres). It slowly reduced the loudness effect as volume naturally increased.
  • [Deleted User]
    edited January 2011
    It's not anything to do with what level audio gear you have, or the listening room. It's a characteristic of human hearing, if you gave yourself a hearing test and lowered the test volumes you'd find that at lower levels we humans are less sensitive to bass and to a lesser degree higher frequencies. Face it, the flatness of our own personal frequency response curves depends upon how loud the incoming sound is.
    The loudness compensation contours were designed to compensate for this fact. At lower volume settings the bass and treble were boosted to give the listener an even frequency response (a little more bass is needed than treble). The problem is when this contour is used at all playing volumes, boosting beyond an even response giving too much bass and treble boost.
    Granted the tuned circuits that create these boosts and cuts often caused more time related problems than the "cure" solved, but nevertheless it is a real consideration.
    Cheers, Ken
    edited January 2011
    I agree Ken with the theory of the phenomenon but why is it with my current gear I hear more at lower levels than I did with my previous gear? All other things being equal. That's where my gear comment came in. Perhaps the phenomenon is still there just to a much lesser degree.
    cnh
    edited January 2011
    steveinaz wrote: »
    I have a Yamaha integrated with that feature and it's nice to have for that unit especially as I use it a lot for low level background music when I write. It is interesting how it applies less and less correction as you increase the variable loudness control knob. An interesting idea...but certainly at normal listening levels the control is off. I, agree, Ken sums it up nicely and that is what I exactly what I hear.
    cnh
  • George Grand
    edited January 2011
    It addresses a human deficiency. Quality gear has nothing to do with it.
    Yamaha had an interesting approach to loudness compensation.
    edited January 2011
    Fletcher and Munson, yes. Interestingly their work has been somewhat refuted over the years. Not the basic premise, but some of the methods and quantitative conclusions. As I recall, later work reduced the relative impact on high frequencies at low levels.
    There is, of course, frequency dependent bias in perception of loudness. Interestingly, I've found vacuum tube amplifiers and high sensitivity speakers display subjectively less need for loudness compensation (heh, I'd argue "no need") at low levels. Nope, cannot explain it.. it's pretty evident, e.g., on pop music with a recorded fade out.
    Yamaha's variable loudness (which was actually quite common in 1950s hifi - e.g., the EICO HF-52 mono integrated, to give one example) was indeed a good idea. Yamaha's curves resembled Fletcher and Munson's.
    I'm sticking with the "more harm than good" opinion, though.
    I actually do use the Yamaha CA-610II's variable loudness sometimes in the family room, when that hifi is being used strictly for 'background'.
  • inspiredsports
    edited January 2011
    No controls in circuit, except perhaps balance.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Knucklehead
    edited January 2011
    Ok...I have a question...
    On my Allied 395 I have the following:
    Bass & treble controls
    Loudness
    Low filter
    High filter
    Do these controls "ruin" the listening experience?
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • inspiredsports
    edited January 2011
    Loudness
    Low filter
    High filter
    I don't know that particular amp (integrated?), but I know that most audiophile mods of vintage gear involve completely removing these circuits and plugging the holes on the faceplate or substituting a new faceplate where the holes are not present.
    Various Dynaco PAS preamp mods are classic examples with which I am familiar where these circuits are neutered, and the sound quality improvement is tangible.
    NAD SS rigs w/mods
    GIK panels
  • [Deleted User]
    edited January 2011
    I had this effect pretty clearly demonstrated to me last week. I've been doing frequency response measurements in my new listening room. I have a RS SPL meter that I've modified to have a flat frequency response down nice and low. I started off with the meter at the 60dB setting and calibrated 1kHz at 0dB. Then I went down in frequency to 20Hz in multiple steps noting what the SPL meter indicated. When I got to below 64Hz it sounded to me like the playing level was dropping, but the meter remained fairly steady. The sound was being produced, but it sounded like it was reduced to me.
    I went to 70dB levels and repeated the process, now the meters showed the exact same response and now it sounded much less like the volume was dropping. At a higher playing volume (10dB increase) the apparent volume level more nearly matched what the meter was showing. I suppose it wasn't important for humans to have super sensitivity to low frequencies as we evolved. We needed our best hearing for quiet sounds in the middle range and upper frequency.
    I've always suspected that some audio systems might have a built in Fletcher-Munsen correction effect by simply revealing a rich harmonic overtone structure which our ear/brain uses to "fill-in" the reduced lower frequencies.
    Cheers, Ken
  • Conradicles
    edited January 2011
    Good stuff Ken!
  • Knucklehead
    edited January 2011
    Yes, its just a late 60's solid state receiver, my level of knowledge would not work with the amount of work that would need to be done, I guess ill enjoy what I have...for now. Thanks for the info.
    David
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    edited January 2011
    ... I suppose it wasn't important for humans to have super sensitivity to low frequencies as we evolved. We needed our best hearing for quiet sounds in the middle range and upper frequency.
    Cheers, Ken
    That's an interesting point; have you read Daniel Levitin's book This is Your Brain on Music? There is an interesting psychoacoustic phenomenon related to harmonic series. If you are played a chord that is missing its fundamental, your brain (auditory processing) will re-insert the fundamental - you'll "think" that it is there. It doesn't work if the series isn't of harmonics (e.g., 100, 200, 300, 400 Hz). Levitin makes the point (as I recall) that at least certain animals have been demonstrated in the laboratory to do this as well.
    Levitin's website:
    http://www.yourbrainonmusic.com/
    EDIT: Oh, and as for the Allied (Pioneer) 395; if you like what the tone and loudness controls do for you; by all means, use 'em! Much of what's being proffered in this thread is opinion; I believe I disclaimed my first post as such (although, admittedly, only after editing a rather more pointed response).
  • Tour2ma
    edited January 2011
    Loudness
    Low filter
    High filter
    If you adjust them so that the music sounds better to you, then by definition they can't be ruining anything.
    I always thought the coolest thing about loudness compensation circuitry was how its impact rolled off with increasing volume levels... even in my lowly starter Heathkit AA-15.
    I suspect that those who feel the level of their gear have allowed them to not miss loudness compensation are listening at higher, minimum spl's than they would were it available to employ.
    More later,
    Tour...
    Vox Copuli
  • RuSsMaN
    edited January 2011
    Loudness contouring is for night listening, higher impact, without the volume. It became a crutch for punchy sound, and those not running the typical 'V' through an equalizer. The 'more is better' crowd, regardless of how it REALLY sounds.
    Loudness never rolled off in your Heath Bruce, you just probably started to clip it, softly. ;)
    At the end of the day, loudness, tone controls, eq - may all be viewed as 'compensating for deficiencies', but if it blows your audio skirt up, who cares? Rock it, and enjoy the music.
    Cheers,
    Russ
  • Fongolio
    edited January 2011
    RuSsMaN wrote: »
    Loudness contouring is for night listening, higher impact, without the volume. At the end of the day, loudness, tone controls, eq - may all be viewed as 'compensating for deficiencies', but if it blows your audio skirt up, who cares? Rock it, and enjoy the music.
    Cheers,
    Russ
    I use the loudness control at low volume and I use an ADC Soundshaper 3 Paraequalizer and I love it. Totally enhances MY musical experience and I don't really care if I'm compensating for deficiancies or not an audio "purist". Sounds great to me and anyone who hears my rig.
    The SDA effect totally messes with the "pure" music signal and most here will agree that SDA's sound great. So who cares? If it sounds good to you than it's good. Period.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • [Deleted User]
    edited January 2011
    To your point, Mark, pipe organ builders knew about the ability of hearing a fundamental frequency if the overtones are played properly. Instead of the expense of making a 64' pipe they would put two 32' pipes side-by-side. When the organist would play the low C on the foot pedal both of the 32' pipes would play and everyone would "hear" the lower note.
    In audio gear most woofers produce fairly high amounts of second order distortion called "doubling". If the signal is 32Hz, for example, the woofer produces 32Hz plus some 64Hz mixed with it. I believe most moderately experienced listeners find higher levels of doubling to sound more pleasing, "richer" bass. Only after being exposed to low distortion bass do listeners begin appreciating the difference.
    Cheers, Ken
