PSW 505 - Setup Question
chaka1234
Good Day,
Just picked up a Polk Monitor PSW 505 Sub to go with my new Monitor 70's and CS2 II, rears will be Monitor 30's when Newegg has them on sale again.
I am running it from an older NAD AV-716 for now, it has a Subwoofer Out which based on the manual states that it provides a "unfitered" output.
Do I connect the output into the LFE (unfitered) or Line In (filtered), the Polk manual is not clear.
I did do a search but could not find any information on this type of setup.
Also I have set the Low Pass to 120Hz, but I have read to set it to 80Hz. Sub volume is at 12:00pm, but I have read to set it to about 10am on the dial.
Thanks.
Thanks.
Post edited by chaka1234 on
Use the filtered input. The LFE input on the sub bypasses the internal high pass relying on the filter in the receiver. HTH.
