RTi mixed with TSi
My current setup is:
Front - Polk Audio RTi A1
Center - Polk Audio CSi A4
SW - Polk Audio DSW Pro 400 8"
I've been testing the f/x wireless surround but have been very unhappy with the results. It works great, but fails to keep a reliable connection. I'm looking to replace that with some wired options.
I've been considering the RTiA surrounds (which is the obvious choice) but looking at the TSi series i like that it comes in Cherry wood which matches my RTi up front. Is it crazy to mix the two? I also like the fact the TSi is a bit smaller.
Once concern i have with the RTiA surrounds is that i can't secure them to a floor stand, and my space is an open area, with the right side being windows, the left being a bit out of the way for wall installation. I could install them on the ceiling but have read that is not recommended.
Anyone have any advice? I can update the post with some room measurements when i get a chance, and some specifics as to what i have to work with.
I'd prefer something small, but have realized that may hamper performance. I like the RM series, but am scared that might be way too small.
Thanks in advance for any advice.
Robert
Robert
Post edited by sphereboy on
The RM would be way too small. The TSI series would do fine in a surround use since timbre matching is more important for the front 3 speakers. I say go for it, let us know how it sounds.HT SYSTEM-
lsi 9's -
Robert
Where did you read that ceiling mounting is not recommended?
I would agree that it is not optimal, but depending on room constraints it is a workable solution - I had to ceiling mount my surrounds - kinda similar to the constraints you described in your room.
I have my RTi4 surrounds ceiling mounted - which is the older model of the RTiA1:
http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount.JPG
Not ideal, but it works pretty good, imo! :biggrin:
Just tossing that out as an option.
The rubber pads that go on the bottom of the Rti Bookshelf speakers have a good grip when placed on stands. Just make sure that your speaker wire is attached to the back of your stand using duct tape. That pretty well anchors your speaker to the stand. If someone bumped into the speaker it really has nowhere to go. I did that with my surrounds, although the stands are enclosed from the floor up to the speaker. That way you can't see the duct tape.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
These new Polk Audio TL2 look very nice. http://www.polkaudio.com/homeaudio/blackstonetl/tl2.php
Anyone have any comments on these. Although i was set on the Fxi i have to to a smaller speaker enclosure for my surrounds. Was looking at the RMs but ran into these new TL series small speakers. -
I just setup my father in law's living room with the TL250 (TL2 5-pack) partnered with a Polk PSW111 all coming together with an entry-level marantz receiver and I was shocked at how well it performed.
The room is pretty huge but they filled it wonderfully !! kept trying movie after movie after and loved it !! These new blackstone's are the real deal
(I'm personally waiting for the TL3 series for my bedroom
Having said all that though, if your using RTi series for your fronts and you can fit the FXi surrounds, go with them! I really like those surrounds. -
I just setup my new TL2 as my surrounds. They sound great. Just like the box says, little speakers with big speaker sound. Small. Heavy. Well built. Can't go wrong buying a pair of these puppies. They can be your surrounds, rears, even add a few more to go 9.1. It's future proof. Highly recommended so far.
Surround - Polk Audio TL2 -
Glad you like the TL's. I am hoping to demo a pair for a bedroom system. Do they have any mounting options such as a keyhole slot on the back?2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Yes it has a keyhole in the back. I'm currently using them on some Sanus home theater stands for the surround.
Sphereboy,you can make a strong set of speaker stands. I gave instructions in another recent post that refers to surround back speakers.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
