Anyone have a Subdude or Gramma under a downfiring sub?
Rivrrat
Rivrrat Posts: 2,101
And if you do, how do you like what it did for the sound?
My equipment sig felt inadequate and deleted itself.
Post edited by Rivrrat on
    EndersShadow Posts: 17,713
    edited January 2011
    I have one under my PSW125. It didnt do to much to the sound (tightened it up a bit), but it sure stopped my walls from vibrating as bad as they did. I have my sub on a carpet over concrete floor in a corner backing up to my apartments firewall.
    I am not sure what kinda insulation the wall behind it has, but I can tell you I felt the vibrations from the sub upstairs in the office even at low levels. The subdude did help with that lots.
    If you share a common wall with someone or are looking to decouple your sub I would suggest it.
  • JuanR
    JuanR Posts: 718
    edited January 2011
    I wound up making my own Subdude (3 to be exact), and they came out pretty good. My cousin has his own music studio so it was easy for me to get some scraps from him. I bought the fabric from a local fabric shop and the MDF board at Menards. Saved me money! As for functionallity, well I have the MicroPro 3000, and it was walking all over the floor. The Subdude will eliminate that, as far as sound, it tightened up the bass a little bit.
  • teamjhertz
    teamjhertz Posts: 363
    edited January 2011
    I have one under my SVS PC Ultra. It is definately is an improvement. The low notes in music were tighter and the really low notes have more impact rather than rattles.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited January 2011
    good info here ....i have used one with good results on downfiring subs...good bang for the buck tweak
    http://www.polkaudio.com/forums/showthread.php?t=96547&highlight=subdude
  • Rivrrat
    edited January 2011
    I think I'm going to build one.
    I got some firm packing foam for the "feet", some "egg carton" foam for between the "feet" from work, and I have some 3/4 particle board laying around for the platform. I'll pick up some felt or someting similar from a fabric store for the platform.
    My sub (Outlaw Lfm-1+) sits on saltillo tile over a concrete slab, but I just think it can do better than it is sitting right on that hard a surface. If it doesn't sound better, I'm not out much money, so I figure I'll go for it.
  • codes1
    codes1 Posts: 17
    edited February 2011
    i use one under my nht subonei it is quite a bit tighter sounding now, but it is a front firing sub. i will try it with the martin logan dynamo which is down firing, get back to you
