Older IC's
organ
organ Posts: 4,969
edited January 2011 in 2 Channel Audio
Just wondering if older IC cables need to be re-terminated? Do the solder joints oxidize over time?
I'm getting good results with an old pair of XLO Pro100 IC's. I purchased them back in 99 or 2000 but I'm sure their production date was way before then.
Post edited by organ on
    F1nut Posts: 52,008
    edited January 2011
    Shouldn't be a problem.
  • fbm211
    fbm211 Posts: 1,488
    edited January 2011
    Give em a shot of pro gold or treat them with some walker audio SST
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • organ
    organ Posts: 4,969
    edited January 2011
    Awesome. Thanks guys.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2011
    if it works and you dig the sound then beyond a little cleaning now then your all set. Its always great when you find some gear or wire etc that totally satifsfies you.
    RT1
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2011
    organ wrote: »
    Yes, but surface only. The solder joint itself won't be compromised.
    The surfaces where you do need to be concerned are the RCA jack and connector. With everything turned off simply break and remake the connection a few times each. Should clean any modest corrosion adequately, and unless you live at the shore or in a heavily polluted city (or still smoke indoors.. :eek:), modest corrosion should be all you experience. I do this every time change... Gold plated connections can be exempted, if you like.
    If you suspect corrosion may be more of an issue in your location, Caig or other cleaner may be warranted.
    More later,
    Tour...
    Vox Copuli
