Sub Setup
Any suggestions on how to setup my sub with the following system. Crossover settings on Receiver has choices of 80, 100, 120. The sub has a dial with those choices and more.
thanks
_______
Onkyo TX-SR600 (receiver)
CSi175 (Center)
R40 Towers (Mains)
Bose 201 (surrounds)
Sony - DVD
Toshiba 36" HDTV
Cambridge Soundworks Base Cube8 (sub)
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
Post edited by mccarts747 on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited July 2003
    Use 100 in the Sony with a sub cable. Set all speakers to small, the sub to on, and set the sub filter dial to the highest frequency setting and leave it there.
    Doc
    SVS
  • VTHokies
    VTHokies Posts: 12
    edited July 2003
    I have a simliar quesiton. After reading through the forums throughly, I decided to bite the bullet and buy a SVS PC+ 20-39 subwoofer. I'm curious as to what are the best crossover settings and set-up for the sub, which arrives tomorrow.
    VTHokies
    Fronts - RTi70's
    Center - CSi40
    Surrounds - FXi50's
    Subwoofer - SVS PC+ 20-39
    Receiver - Harman Kardon AVR525
  • Dr. Spec
    edited July 2003
    VTHokies
    Fronts - RTi70's
    Center - CSi40
    Surrounds - FXi50's
    All speakers to small
    80 Hz crossover
    Set the subwoofer channel level to -5
    Set the PC+ filter switch to Disable
    Use L or R low level input
    Set power to Auto On on PC+
    Calibrate subwoofer level at the PC+ amp
    SVS
