Windows 7 starter
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2011 in The Clubhouse
I got the wife a netbook that has Windows 7 starter. Anyone tried upgrading to 7 Home Premium? Apparently, a lot of programs don't run on the starter. The netbook as 1 gig RAM and is like 1.8 gHz with 250g storage.
thanks
Post edited by NeilGabriel on
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited January 2011
    Yeah, starter is limited to (I think) 4 programs running at once. That netbook is definitely an over-powered netbook, and would be better suited with Premium on it.
    You can either do a format and install (I recommend) or you can do an upgrade. They sell both types.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
    heiney9 Posts: 25,419
    edited January 2011
    I don't believe you can run a full W7 w/1G of ram.
  • ryanjoachim
    edited January 2011
    heiney9 wrote: »
    You can. I'm running Windows 7 Premium (x86) on my wife's 1GB/1.8Ghz 5yr old laptop right now. It does fairly well.
    Granted you'll get a much smoother ride with 2GB+, but it's definitely doable with 1GB.
    Disclaimer - Your experiences may vary!
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • NeilGabriel
    edited January 2011
    I had seen recommendations for 1 gb, but apparently not essential. I am not sure what programs will not work with 7 Starter....e.g., Adobe Photoshop.
    I did download the McAfee Security Essentials and had no problem with that.
  • Topper
    Topper Posts: 403
    edited January 2011
    thats weird - i'm running win 7 starter on a few of our laptops with no issues whatsoever. Infact for no frills comp use, i really don't see any reason to both upgrading to anything higher
