5 Jr's Blown Tweeter?
sbolt
sbolt Posts: 12
edited January 2011 in Vintage Speakers
First, thanks for all the info on this board, it has been extremely helpful.
I just received a pair of 5 Jr's made in 1987 according to the date on the back of the drivers. These speakers have the SL-2000 tweeters I believe as the visible leads on the plate are parallel to the floor.
One of these tweeters has lower output than the other, but it is still working, but not overly scratchy or anything. I swapped the speaker from left to right and sure enough it's the speaker, not the amp.
Would the lower output dictate the need for a tweeter replacement or should I wait until after I refurb the crossovers (as planned) before judgement?
thanks!
Amp: Denon PMA 320
Speakers: Polk Audio Monitor Series 4
Polk Audio Monitor Series 5 Jr's
Blu-Ray: LG BD570
Panel: Panasonic TCP42U2
Post edited by sbolt on
  • Big Dawg
    Big Dawg Posts: 2,005
    edited January 2011
    Absolutely wait until after you refurb the crossovers, since I suspect that what you've got is a dying polyswitch. Switch only the tweeters and I think you'll see what I mean. Might want to consider upgrading the tweeters anyway, though.
    Oh, and welcome to Club Polk.
  • george daniel
    george daniel Posts: 12,096
    edited January 2011
    did you swap the tweeters?
  • sbolt
    sbolt Posts: 12
    edited January 2011
    Thanks for the quick responses.
    I have not swapped the tweeters yet, but I will try that next
    The polyswitch is the small, blue, flat rectangular thing measuring about
    5 x 8 mm right alongside the capacitor correct?
    Amp: Denon PMA 320
    Blu-Ray: LG BD570
  • george daniel
    edited January 2011
    yep,, if it is the culprit,you can just remove it and replace with another,or a jumper,or a .5 ohm resistor,,if you opt to replace it with a jumper or a resistor,just be careful with the volume,good luck,let us know what happens.
    You may first want to rule out the tweeter as the suspect.
  • sbolt
    sbolt Posts: 12
    edited January 2011
    It's the tweeter. I swapped them around and it's definitely the tweeter. Looks like I'll be making a list.
    Amp: Denon PMA 320
    Blu-Ray: LG BD570
