First Real Surround System
scorpionturbo
Hi everybody. My GF bought me Monitor 60 series II and a PSW10 sub for Christmas. She thought we had a receiver in the basement that we could use. I figured it was a good excuse to buy a new one! So the Monitor 60's have 2 outputs on them... not sure how to wire. Also They look really odd right next to my TV. What is the best way to set up a 5.1 (1 sub) and have 2 speakers going to different room. Or do 7.2 with everything? Here is what I'm working with:
Mitsubishi 57" DLP 1080P
PS3
ONKYO HT-RC260 7.2 receiver
(2) Polk T-15 Bookshelf speakers
(2) Polk Monitor 60 series II Towers
(1) Polk CS2 Center
(1) Polk PSW10 Sub woofer
(1) Klipsch 10" down firing sub woofer
I forgot to add that the TV is in a corner and there is a bay window on the left and regular window on it's right. I was thinking of putting one tower on the left bay window and the other on the right of the regular window... would it matter since I have a center speaker if the others weren't near it? The receiver has mic setup btw..
Thank you for your input in advance
PS3
(1) Polk CS2 Center
Post edited by scorpionturbo on
Buy a receiver with 7.1 and dual zones... You can just hook up the 5.1 and then 2 channels to another room.
The INPUTS on the monitor 60s are for biamp/biwire. You won't need to worry about that. Just hook up the wire to one set of the jacks.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I will be wiring it up tomorrow. Thank you for your advice and I'm sure I'll be back for more help. Nite forum
