Subwoofer for Luxman R 117
Hello,
Does anyone know if there is a way to connect a powered subwoofer to a Luxman 117? Thanks very much for your assistance.
Upstairs Rig
Luxman R 117 Reciever
Denon CD Player
Denon DP 45-F Turntable/ Denon 103 Cart
Polk SDA 1C Speakers
Mancave Rig
Carver TFM-35x Amp
Marantz 2252B used as Preamp
Pro-Ject 1.2 Turntable/Sumiko Pearl Cart
Pioneer Elite CD Player/Recorder
Polk SDA II Speakers
Post edited by Jiminypage on
  • MADGSF
    MADGSF Posts: 603
    edited January 2011
    If it does not have a sub out connection you will need to get a sub with line level (Speaker level) inputs. Most of the subs Polk makes have line level inputs. You would connect from the Luxman speaker out, to the sub and then to your speakers.
    Hope that helps.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • Jiminypage
    Jiminypage Posts: 19
    edited January 2011
    Thank you for your help MAD. The receiver does have a pre out, which I'm assuming I could also use as line level inputs to the sub. My sub, POLk PSW 110 has line and speaker level inputs. Is there are preferred way to do this? My main speakers are SDA ICs.
    thanks again!
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
  • MADGSF
    MADGSF Posts: 603
    edited January 2011
    I assume the pre out is specifically labeled "sub". If that is true the easiest way is the pre out and that is the only method I have personally used. If you go the line level route there will be extra speaker cables but otherwise they should both work the same. I would start with the pre out and spend some time dialing in the sub.
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
