Question about MM100
Systems
I have two of the original MM100 (I don't know if the new ones have the same model name/number) and I was in my car the other day when I heard this popping sound.
I took the sub out that the sound was comming from and one of the speaker leads (inside the speaker) came off the post. Now, the company where I bought the speaker has gone bankrupt within the last month and I was told I can't get a receipt.
Also, if Polk will replace the messed up sub, will they replace it with the same model? (Because I dont really want two different model, one new & one old)
Do I try to solder it back on the post myself?
Please help! Thanks
Please help! Thanks
Testing
Testing
Testing
Testing
Testing
this was a problem with the old mm100s and 120s
a lot of people have just soldered it back on and have been fine with them afterwards
just be very careful
-Cody -
My subwoofers are about 1 year (maybe a little more) old and I bought them from Colorado Custom Home Entertainment.Testing
Testing
Testing -
ya if they're stil under warranty (like less than 3 years i think) and u got them from an authorized dealer, polk will probably just give you two new subs...
if not -- solder that sucker on... you can even add 1 inch of 16 gauge wire onto there if you want to prevent it from happening again -- just better solder it damn good or 1- you'll burn the lead, 2- you'll have it fall of... 3- god will hate you.
good luck dudeThe Artist formerly known as PoweredByDodge -
I don't have my original receipt and, like I said in my original post, when I contacted the owner of the company...he wouldn't issue me a receipt because they're going bankrupt.
On another note: What could cause the speaker lead to fall off like that? If I have it soldered back on to the post, is there a chance that it having come off damaged anything else in the sub?
Thanks for the help!
TylerTesting
Testing
Testing -
tyler, u're best just swapping them out - from the way kim sounds, they're gonna hook you up with new ones without a sweat, so jump on it dude.
if you really wanna try to fix the darn thing though -- its not major surgery -- and unless you overheat the tinsel lead wire when u go to solder it, then u wont hurt anything -- if u do overheat it, you can jackup the glue job where the lead goes throgh the cone and toward the coil... hell u can even damage the coil.
its something i reccomend only when warranty is not available, in which case, minor surgery is usually more appealing then forkin out cash for a new sub.The Artist formerly known as PoweredByDodge -
So I should send them both back? Or if I send just the one back will it get replaced with the same model?
Thanks againTesting
Testing
Testing -
what kim is saying is that if you send both...theyll send you 2 of the new models...even though only one is broke
-Cody
