Carver c-1 preamp (HOLOGRAPHY) in system w/MAGGIES
dee1949
dee1949 Posts: 1,425
edited January 2011 in The Clubhouse
.....anybody try this setup, before I tear my system apart to add the C-1???
...have the Magnepan MG-1's out in the room....at least 3 ft away from walls.
....how does the HOLOGRAPHY sound with bipolar speakers?
Post edited by dee1949 on
  • dee1949
    edited January 2011
    ....anybody with Maggies definitely should have a copy of "Jazz at the Pawn Shop". Just want to know if it is worth the effort to improve on the experience of this CD?? Will the "H-effect" have a unique quality (positive)?
    nooshinjohn Posts: 25,932
    edited January 2011
    I have SH on my Sunfire pre and never use it with my SDA's, but I have run it when I had the LSi's up front and found that I liked the effect for certain types of music. I would say give it a try. The C1 is a pre worthy of your time whether or not you decide to use SH.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    I found it to be a useless component on my Magnepan.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    dorokusai wrote: »
    Now THAT post is helpful.....NOT!
    Anyway, I did a re-cap and op-amp upgrade on my C-1 last year that really brought an already good sounding component into the great sounding category. I had to use adapters on the 14 pin quads that allowed two National Semiconductor LM4562 duals to work but man was it worth the time and money. I strongly recommend this mod. I haven't heard a C-1 with Magnepans but anything I've put the C-1 with has sounded sweet. It sounds awesome with the SDA's I have but not with sonic holography engaged. On other speakers though, I very much like the SH effect. The C-1 has one of the best SH circuits as well. I say go for it. Your ears will tell you.
    Kelvin
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dorokusai
    edited January 2011
    He already owns it and I never said NOT to do it Johnny Bravo. You liked it, I didn't....and the world keeps turning.
    edited January 2011
    dorokusai wrote: »
    Your distain for all things Carver is showing again Doro...:rolleyes:
  • dorokusai
    edited January 2011
    That may be true but I at least try and put forth the effort to learn and I've owned dozens of Carver pieces. That way I can rag on it or praise it in whatever manner I see fit. Did you care to know what I thought of it aside from Magnepan? Nope. I have to move on to other issues, happy listening!
  • George Grand
    George Grand Posts: 12,258
    edited January 2011
    Only 6/10 for hostility. Great form though.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    GG - I'm gonna go 7/10 for classic Club Polk honesty and form! We need to get back to the basics that make this place rock!
    DKG999
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2011
    I used C-1 with my rebuilt MGII Maggies for almost two years before I went with tubes. To be honest, holography never fully matched with Maggies sound for me, so I always had it off. Maggies are finicky to setup and find a good place for to begin with. Holography added another dimensions, which made the whole setup a big headache. On the other side, C-1 is an excellent preamplifier, so why not try your Maggies with C-1 and tell us what you think?
    Oh yeah, Maggies are not 'bipolar', they are 'planar'. http://stereos.about.com/od/glossaryoftermsb/g/bipolar.htm
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2011
    Did I miss the part where Doro actually has used a C-1 with Maggies? You know... the actual bit o' experience that qualifies him to respond to the OP?
    Or does the (non)action of specifically (not)hearing them with Maggies better qualify others?
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    While I revere Carver speakers, love Carver amps....and the C19 tube preamp is, IMO, a giant killer, I have little love for the C-1 preamp. It's ok, not great....YMMV.
    In regards to the Maggies, you are going to have to reposition them....if you don't set up your speakers and listening position in the prescribed fashion...the SH doesn't work nearly as well.
    I'm not saying don't do it....as you have the piece, why not? I just think the soundstage that the Maggies throw on thier own is damn impressive so I don't think there is much to be gained.
    YMMV.
    BDT
  • shack
    shack Posts: 11,154
    edited January 2011
    I dunno...I took the above statement to mean he had tried the combination. :confused:
  • zombie boy 2000
    edited January 2011
    I know. I was responding to a previous post that was trying to call him out, but explicitly mentioned having never tried the combo themselves.
  • shack
    shack Posts: 11,154
    edited January 2011
    Oh...ok. Your post was confusing...I ignored the sarcasm part...
  • dee1949
    edited January 2011
    ...Thanks for reply's. Will put the experiment on hold til I need to tear my system apart for a different reason. I am using a B&K pro10mc preamp, which I am happy with for now.
  • Fongolio
    edited January 2011
    I think he means me. And I responded to Doro's statement of "useless" only because without any other observations such as why he found it "useless" or with what other components were in the chain, the statement on it's own is exactly what he calls the combination he's offering insight on........useless.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • shack
    shack Posts: 11,154
    edited January 2011
    Fongolio wrote: »
    The OP only asked how it sounded. The answer was succinct and to the point.
