Which speakers would be best?
st382
st382 Posts: 2
edited January 2011 in Speakers
hello, i have a polk blackstone tl150 set with a denon 2310ci 7.1 receiver. i was thinking about gettin a set of floorstanders or good set of bookshelfs to use as fronts but dont know what will match with what i have already. my uses are mainly movies and music. any help is appreciated.
thanx
Post edited by st382 on
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    Nothing current will match the tweeter of the center. It's a new tweeter. The closest would be a LSi series because it's a ring tweeter.
    If you want a new front stage, you'll need Front and Center so it matches.
    How much are you willing to spend, and how big do you want to go?
    You can always get RTi-A9 + CSi-A6
    Main Surround -
  • st382
    st382 Posts: 2
    edited January 2011
    would tl1's and tl2's match together?
