Amplifier Math
avphile
If my pre processor (Pioneer 84TXsi) volume settings goes from -85dB to 0dB. And my amplifier (Sunfire TGA5200) is rated at 200WPC into 8Ohms. Assuming that the speaker load remains 8Ohms over the entire frequency range (0-20KHz). Is this correct
Pioneer w/o Amp
140/85 = 1.65 W per dB volume.
Pioneer w/ TGA5200
200/85 = 2.35 W per dB volume.
Pioneer w/ TGA7400
400/85 = 4.71 W per dB volume.
Therefore, the sound will be louder if I have a higher wattage amplifier. But the problem is that the loudness I am hearing is not that significant.
Pioneer w/o Amp
Pioneer w/ TGA5200
Pioneer w/ TGA7400
I'm probably the wrong person to answer this, but let me ask a question and see if this points you in the right direction.
Is the power of the amp stackable? What I mean by this, is the AVR itself is 140 watts. Your amp is 200 watts. Correct me if I'm wrong, but I believe if you're using the amp - you are using 200 watts (not 340)
I could be completely wrong, but this is what comes to mind for me.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I don't think that's correct. dB is a logarithmic thing, not a linear one, so the math just wouldn't work like that.If you will it, dude, it is no dream.
