AVR or Seperate Processor
larry777
Hi everyone. I am still gathering information and learning what I can about my options for buying another AVR and after that possibly an amp. At this point I am leaning towards the Pioneer SC-35 but I started to think about seperate processors as well. Used processors don't seem to have HDMI like the Parasound and others. To get the Blu Ray sound and picture is it just a matter of running an HDMI cable directly to the TV for Picture and then running an Optical Cable to the Processor for the highest grade sound ? Or would I have to use the 7.1 Outs on my Blu Ray player to the Processor ? Would it just be better to get the AVR rather than a processor without HDMI ? I use RTi10's,CSiA6 Center,Rti4 surrounds ( Surrounds will likel get upgraded later on ). Thanks for your thoughts.
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Post edited by larry777 on
This is a horrible review, btw.
To get the best picture and sound, you want to run the HDMI to the receiver, and then an HDMI out to the tv.
If you have the Pioneer SC-35 it will decode the high definition sound formats via HDMI and pass the picture to the tv with the highest resolution format. Ditch the old optical cables, they're outdated.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Ok,maybe I should have went into a different area than Review,so I will watch for that next time. Thanks for your reply howerer. It does sound like these Non HDMI Processors are outdated then, as far as Blu Ray capability goes. I don't have the SC-35 yet but was at the top of my list for a new AVR. I think I will forget the Processor option then and go with the AVR. This way I could look at a 3 channel Amp later on ( Rather than a 5 or 7 ) to run my front three ( L,R,C ) and let the Receiver run the surrounds. It seems like the better option all around.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Van Den Hul Interconnects -
You can still have your Blue Ray player do the decoding and send it out via analog to the pre/pro for it to play. However normally in the BD player the bass managment and other features won't be as good as the ones found on the pre/pro (sometimes) and you would have to see if you could still use any sort of sound processing etc when doing the analog in's as sometimes it will bypass and just be a "through" so there would be no bass managment, auto calibration etc that the pre would add, all the set up would be in the player.
Once again HDMI is going to be the easiest, but depending on the processor, and the player analog can sound great as well. Just depends on what you are after etc.
The SC series is awesome and I use one myself (SC-05). Awesome system and would never want to really change it out for anything less at this point ever. -
Get a preamp with hdmi or get a pioneer sc , dont go for optical its not hd sound
You can't go wrong with the SC-35. The Marvel processor does an excellent job upconverting even the older DVD's in my collection look superb. Listen to the others about the HDMI config
Good luck2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Ok,thanks for the comments guys. The Pioneer SC-35 seems like my best first move. I can then add an amp later.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Excellant choice there, let us know your impressions when you get it all set up and changed your shorts.
