In Wall Front Speaker Distance
Gomez81
Gomez81 Posts: 10
edited January 2011 in Speakers
Hey Fellas,
Going to install my Polk TC265i's today to begin my HY overhaul. I am a little confused on spacing. As I have it templated now, The mid point of the speaker is 57 inches from the middle of LCD on wall (leveled). The distance from TV to main listening position on couch against back wall (wife wont allow moving couch forward) is 13 feet. It is about 14 feet from the sweet spot to each template on the wall. By my calculations, this make the angle from my listening position between TV and speaker's approximatey 20 degrees.
I know the ideal angle is 22-30 degrees. If I go to the next bay, I will be less than 2 feet from walls.
Is this a good angle as I have it? I will almost certainly know that the tweeter's will be aimed slightly inward. Any comments will greatly be apprecited.
BTW, I am also planning to put fiberglass insulation in bay above and below speaker. How far above/below speaker does anyone suggest to start loosely filling cavity?? Should some be placed directly behind to absord back waves??
-bump if in wrong section-
