Two PSW111 better than one?
cbad
I have a PSW111 in a fairly good sized room (15'x18'). I just got another one for free. I wondering if I can hook them both up and if I did what benefits I might get. I'm also considering getting a bigger sub instead, but the two will fit in my room much better. Used for both music and HT, but probably more HT.
Thanks!
Thanks!
Post edited by cbad on
One high end Sub much better than two(2) Low end or Mid end Sub,I would sell both get SVS Sub...TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
cbad,
Welcome to the Club!
While there are a couple of threads in this forum that will give you plenty of advice and infinite opinions, here is a link to an article that may help you with answering your question:
http://www.harman.com/EN-US/OurCompa...ions/13680.pdf
I am not an expert in this arena. However, I went from one decent sub to two and liked the end results of having two (for 2 channel and home theater).
Try the two subs and use your ears to make the final decision. -
Thanks! -
toucanet is dead on, multiple subs are the way to go."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Pinktulip7 wrote: »I would sell both get SVS Sub...
Thanks! -
Let's try another way (attachment).
Thanks! -
Make sure calibrate both Sub...TV :>Panasonic TC-P55VT50
