SURROUNDBAR 3000 and Woofer and Microphone
tghorai
tghorai Posts: 4
Hi,
I purchased a SURROUNDBAR 3000 and Woofer. Can you please help me what all things I needed to buy to use a microphone with this sytem. I preferred to have wireless Microphone. Any brand name you suggest would be great to get better quality.
Regards
Tanmay
    edited December 2010
    The surroundbar isn't ment to be used with a microphone. Explain what your trying to do and we can better steer you to achieve it.
  • tghorai
    tghorai Posts: 4
    edited January 2011
    Hi,
    I would like to perform in-house small kid's Programs etc. Would like to use as Karaoke. Can I buy a Microphone and its receiver so that, Voice can be loud through woofer and speaker?
    Appreciate your assistance.
    Regards
    Tanmay
  • dorokusai
    dorokusai Posts: 25,661
    edited January 2011
    tghorai wrote: »
    Hi,
    Regards
    Tanmay
    You need something a little more geared specifically towards karaoke. The are ways that you could make this work but it would ultimately involve more stuff and equipment than I think you're really wanting.
    I imagine you need something quick and easy to setup and while the Surround Bar is a solution for home applications, as in home theater....it's not so much for karaoke and portability. I cant think of an easy and small way to do what you want.
    They make small karaoke machines you know?
    Mark
