2.3TL Xover complete how-to list?
gemohler
gemohler Posts: 11
edited December 2010 in Vintage Speakers
I have a set of 2.3TLs that Ive had for years, and another set of 2Bs that ive had since the day I bought them brand new in 91.
Im already planning to upgrade the tweeters to RDO-194's.
I do need two replacement drivers for the 2.3's, one driver on each side is not working (the mid drivers)
However, I _really_ wanna do the Xover upgrade, and im a total n00b with electronics.
Im looking for a really good master document on "what and how to do" this job.
Ive been many pages of threads back..and Ive seen a number of good photos, and such..but just looking for a recipe.
Thanks!
Post edited by gemohler on
    F1nut Posts: 51,772
    The 2.3TL's use the RD0198-1.
  • ben62670
    ben62670 Posts: 15,969
    All you do is replace the old components with new ones. I don't know what your soldering skills are like, but if you are new at it you should practice on some old electronics boards. A cold solder joint can be a real pia to figure out. Do one XO at a time so you have a reference. Also don not cut the legs on the XO components so if you need to move something a little bit you have not screwed yourself. Soldering isn't for everybody. Some people just can't pull off good joints. Like myself I can not do a good job of sheet rocking.
    Enjoy
    Ben
    Ben
  • gemohler
    gemohler Posts: 11
    ben62670 wrote: »
    Enjoy
    Ben
    Ya..I can grok the soldering, I was more concerned with the components choice of WHAT to replace on the boards.
  • ben62670
    Replace all the caps and resistors.
    http://www.polkaudio.com/forums/showthread.php?t=55888
    Ben
  • gemohler
    gemohler Posts: 11
  • Polkersince85
    Polkersince85 Posts: 2,883
