Please Clarify for me!
Ok so I've been reading so many contradicting things on the internet...can anyone please give me the correct settings (or at least where to start) for my bass management...here's how i have it set up now.
Yamaha RX-V1065 Receiver
Monitor 70 fronts
RM8 Surrounds
CS20 Center
PSW110 Sub
The sub is hooked up to the receiver through the sub out into the LFE in.
On the receiver i have LFE/Bass Out set to BOTH and Bass Crossover Frequency set to 40hz. The knobs on the sub are set to volume at 12 o clock and the low pass set all the way over to 160hz like the yamaha's manual says to do (unless I'm reading it wrong, which is a strong possibility haha).
So my big questions are what should I have the receiver settings set to? How should I have the sub hooked up (ie. with the LFE cable or with speaker wire through the speaker in/out)? And where should the knobs on the back of the sub be set to? I just feel like the sub is not even there, very flat no bass from the system as it stands right now.
Post edited by xgnarlycorex on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited December 2010
    Set the receiver crossover to 80hz, crossover should be set like you have it...all the way to 160hz, personally, I usually leave the volume all the way up, but thats just me.
    David
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • xgnarlycorex
    xgnarlycorex Posts: 32
    So keep it set to BOTH and don't mess with the cable? Just curious because if you read the PSW110's manual it tells you to go the speaker in/out route i think.
  • Knucklehead
    yes, receiver to 80hz and sub to 160hz. Your cable should be fine.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • xgnarlycorex
    ok thanks! I'll take it for a test drive today.
  • Knucklehead
    let us know what happens.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • xgnarlycorex
    PLayed some Need for Speed and the bass seemed heavier..I turned the volume up on the sub a little and that helped alot...will watch a movie on the ps3 later today/tonight.
  • Knucklehead
    great, keep tweaking until you find what sounds good to you.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Matt34
    Matt34 Posts: 318
    Monitor 70 fronts
    RM8 Surrounds
    CS20 Center
    PSW110 Sub
    In regards to your LFE/settings if your system has a subwoofer the ONLY place your receiver will send LFE is to the subwoofer, whether you use the SUB or BOTH setting. LFE and bass are two different things. LFE is the specific .1 channel of a movie's soundtrack. What the BOTH setting does is it sends the bass (not LFE) from the front channels to BOTH the front speakers as well as your subwoofer. So this setting duplicates the bass in your front channels, that is below your crossover setting, at the subwoofer. It does nothing to the LFE. LFE always comes out of the sub and the sub only (when you DO have a subwoofer). Of course, whether you use the SUB or BOTH setting, any bass below your crossover setting from speakers set to SMALL is sent to the subwoofer.
    IMO I would set the LFE/Bass to Sub and cross over at 80hz and work from there. Your center and surrounds can't do 40hz and it's at the very bottom end of what your mains are capable of.
    If you run the YAPO sound optimization program you need to turn your subwoofer's gain to around the 9-11 o'clock position and then run the YAPO. Unfortunately YAPO generally does a poor job of setting the signal output from your AVR so you may have to go back into the setting and adjust it to taste. A SPL meter would be very beneficial in making these fine tune adjustments.
    Your sub isn't an output monster but using these setting might give you a better experience with it.
  • xgnarlycorex
    I have the fronts set to large and the center/surrounds set to small...is this correct?
    txcoastal1 Posts: 13,499
    set all to small
  • xgnarlycorex
    Oh really? The Monitor 70 manual says Large?! Thanks for all the help by the way guys.
  • Knucklehead
    txcoastal1 wrote: »
    set all to small
    yep....what he said.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • halo71
    halo71 Posts: 4,628
    I would also keep in mind that sub is not gonna give you the gut moving impact you may be expecting it too.
    --Gary--
